跳转到主内容
加入维修社区 - 创建账户
Alcatel OneTouch Evolve Camera Replacement
你所需要的
  1. Alcatel OneTouch Evolve Camera Replacement, Locate the access tab: 步骤 1 中的图像 1,1
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
    询问修复机器人
    添加评论
  2. Alcatel OneTouch Evolve Camera Replacement, Place the flat head end of the pry tool into the tab: 步骤 2 中的图像 1,3 Alcatel OneTouch Evolve Camera Replacement, Place the flat head end of the pry tool into the tab: 步骤 2 中的图像 2,3 Alcatel OneTouch Evolve Camera Replacement, Place the flat head end of the pry tool into the tab: 步骤 2 中的图像 3,3
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
    询问修复机器人
    添加评论
  3. Alcatel OneTouch Evolve Camera Replacement, Identify the Battery: 步骤 3 中的图像 1,1
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
    询问修复机器人
    添加评论
  4. Alcatel OneTouch Evolve Camera Replacement, Removing the battery: 步骤 4 中的图像 1,2 Alcatel OneTouch Evolve Camera Replacement, Removing the battery: 步骤 4 中的图像 2,2
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
    询问修复机器人
    添加评论
  5. Alcatel OneTouch Evolve Camera Replacement, Locate Screws Holding the Secondary Panel in Place: 步骤 5 中的图像 1,1
    • There will be eight 4.5mm screws that fit your Phillips head PH00 screwdriver notated by the red circles in the image.
    询问修复机器人
    添加评论
  6. Alcatel OneTouch Evolve Camera Replacement, Remove Screws: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Unscrew each screw, counter-clockwise (left), until each one has been removed.
    • If necessary, use tweezers to fully remove the screws from the device.
    • Remove battery before lifting off the panel.
    询问修复机器人
    添加评论
  7. Alcatel OneTouch Evolve Camera Replacement, Prying the Panel Off: 步骤 7 中的图像 1,3 Alcatel OneTouch Evolve Camera Replacement, Prying the Panel Off: 步骤 7 中的图像 2,3 Alcatel OneTouch Evolve Camera Replacement, Prying the Panel Off: 步骤 7 中的图像 3,3
    • Access the small pry tool in the tool kit
    • Place flat head in the crease between the phone and panel where the matte finish meets the shiny finish of the front of the phone.
    • Rotate the pry tool 90 degrees until part of the panel lifts up
    • All areas need to be fully risen off before the panel can be removed.
    • Do not use the opening tool to pry open the device near the power button or near the volume button.
    询问修复机器人
    添加评论
  8. Alcatel OneTouch Evolve Camera Replacement, Locate the Camera on the Device: 步骤 8 中的图像 1,1
    • See yellow square for the location of the camera on the mother board.
    询问修复机器人
    添加评论
  9. Alcatel OneTouch Evolve Camera Replacement, Unclip the connection to the motherboard.: 步骤 9 中的图像 1,2 Alcatel OneTouch Evolve Camera Replacement, Unclip the connection to the motherboard.: 步骤 9 中的图像 2,2
    • By gently lifting the bottom rectangular piece of the camera component upwards and away from the device, the connection will come free.
    • Remove the rubber casing from the camera, this piece is simply resting over the camera and can easily be removed.
    询问修复机器人
    添加评论
  10. Alcatel OneTouch Evolve Camera Replacement, Separate the camera from the glue patch: 步骤 10 中的图像 1,2 Alcatel OneTouch Evolve Camera Replacement, Separate the camera from the glue patch: 步骤 10 中的图像 2,2
    • Place your plastic opening tool underneath the bottom of the camera and rotate the tool to lift the camera. This will take a slight amount of force.
    • You will start to see the silver sticky patch between the camera and the mother board - leave this on the mother board.
    • Keep separating the camera from the sticky patch until completely removed.
    • To replace camera, use the yellow lines on the motherboard as your guide.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
团队
UMass Dartmouth, Team 4-5, Miles Fall 2014 UMass Dartmouth, Team 4-5, Miles Fall 2014 的会员
UMASSD-MILES-F14S4G5
3 名成员
创作了24篇指南
1指南评论
Thank you kindly for your time to write the tutorial.
Tina Mccraney - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 28
总计 2,055
