跳转到主内容
Alcatel OneTouch Evolve Battery Removal
你所需要的
  1. Alcatel OneTouch Evolve Battery Removal, Locate the access tab: 步骤 1 中的图像 1,1
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
  2. Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: 步骤 2 中的图像 1,3 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: 步骤 2 中的图像 2,3 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: 步骤 2 中的图像 3,3
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
  3. Alcatel OneTouch Evolve Battery Removal, Identify the Battery: 步骤 3 中的图像 1,1
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
  4. Alcatel OneTouch Evolve Battery Removal, Removing the battery: 步骤 4 中的图像 1,2 Alcatel OneTouch Evolve Battery Removal, Removing the battery: 步骤 4 中的图像 2,2
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
结论
12等其他人完成本指南。
Brendan Egan
于10/28/14注册
2,467 声望
创作了5篇指南
团队
UMass Dartmouth, Team 4-5, Miles Fall 2014 UMass Dartmouth, Team 4-5, Miles Fall 2014 的会员
UMASSD-MILES-F14S4G5
3 名成员
创作了12篇指南
5条评论
Thanks 4 the info.
dennisp1964 - 回复
my phone is rooted
next time i,m delete all software
now my phone show only lock screen
how to install my old software
Noushad Marshi - 回复
Thank you very much!
Kath B - 回复
Easy and clear instructions! I am 95 yrs old and I found your instructions wonderful! Thank you Helen Spriggs
Helen Spriggs - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 18
总计 10,039
