跳转到主内容
加入维修社区 - 创建账户
Alcatel OneTouch Elevate SIM Card Replacement
你所需要的
  1. Alcatel OneTouch Elevate SIM Card Replacement, Battery: 步骤 1 中的图像 1,3 Alcatel OneTouch Elevate SIM Card Replacement, Battery: 步骤 1 中的图像 2,3 Alcatel OneTouch Elevate SIM Card Replacement, Battery: 步骤 1 中的图像 3,3
    • Locate the small indent on the lower left corner.
    • Use your fingers or a small plastic opening tool to lift the back cover off.
  2. Alcatel OneTouch Elevate SIM Card Replacement: 步骤 2 中的图像 1,3 Alcatel OneTouch Elevate SIM Card Replacement: 步骤 2 中的图像 2,3 Alcatel OneTouch Elevate SIM Card Replacement: 步骤 2 中的图像 3,3
    • Locate the indent between the battery and your phone.
    • Use your finger or a small plastic opening tool to lift the battery free.
  3. Alcatel OneTouch Elevate SIM Card Replacement, SIM card: 步骤 3 中的图像 1,2 Alcatel OneTouch Elevate SIM Card Replacement, SIM card: 步骤 3 中的图像 2,2
    • Locate the SIM card slot at the top left of the phone.
    • If an SIM card is not present, you can skip to step 4
  4. Alcatel OneTouch Elevate SIM Card Replacement: 步骤 4 中的图像 1,1
    • The SIM card will have an indent at the top, use this to carefully pull the card from the slot.
  5. Alcatel OneTouch Elevate SIM Card Replacement: 步骤 5 中的图像 1,2 Alcatel OneTouch Elevate SIM Card Replacement: 步骤 5 中的图像 2,2
    • Grab the new SIM card making sure not to touch the metallic area.
    • With the metallic patch facing down, insert the card into the slot.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 34
总计 972
