简介
If your volume and/or power button is not working and you have already cleaned away debris this guide will show you how to replace the assembly to fix the problem.
你所需要的
Begin working by using the plastic opening tool to remove the back cover of your Alcatel One Touch Pop 7. Opening the flap as shown in the picture will give you an easier start.
结论
To reassemble your device, follow these instructions in reverse order with the new volume button assembly replacing the old one.
另外一个人完成了本指南。
