简介
A faulty motherboard could cause many problems as it is the core of the device. This guide will show you how to replace the motherboard and should fix a whole host of problems you may be having.
你所需要的
Begin working by using the plastic opening tool to remove the back cover of your Alcatel One Touch Pop 7. Opening the flap as shown in the picture will give you an easier start.
在这个步骤中使用的工具:Tweezers$4.99
The camera is in the top left corner of the tablet. To begin removal, use the tweezers to gently disconnect the ribbon cable attached to the camera.
Using the tweezers, pull the WIFI Antenna away from the motherboard and the wireless card.
We now need to remove 3 ZIF connectors, all located in the bottom right quadrant. The order they are disconnected doesn't matter.
3等其他人完成本指南。
一条评论
do you think i could find a controller board for this lcd screen? so i can give it a second life email me if you willing to help me santiproxgamerxd1@gmail.com. Thanks!
