跳转到主内容
Alcatel One Touch Idol 3 Battery Replacement
你所需要的
  1. Alcatel One Touch Idol 3 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Alcatel One Touch Idol 3 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Alcatel One Touch Idol 3 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the sim tray by inserting a sim removal tool and then pulling it out.
  2. Alcatel One Touch Idol 3 Battery Replacement: 步骤 2 中的图像 1,3 Alcatel One Touch Idol 3 Battery Replacement: 步骤 2 中的图像 2,3 Alcatel One Touch Idol 3 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the back cover by moving around its perimeter with a thin object that can fit.
    • Eventually you will be able to pry open the back cover.
    • Although a razor is depicted, we recommend using ESD-safe pry tools instead.
  3. Alcatel One Touch Idol 3 Battery Replacement: 步骤 3 中的图像 1,2 Alcatel One Touch Idol 3 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the protective sticker from the battery connection.
  4. Alcatel One Touch Idol 3 Battery Replacement: 步骤 4 中的图像 1,2 Alcatel One Touch Idol 3 Battery Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery's connection to the motherboard by lifting it upwards.
  5. Alcatel One Touch Idol 3 Battery Replacement: 步骤 5 中的图像 1,2 Alcatel One Touch Idol 3 Battery Replacement: 步骤 5 中的图像 2,2
    • Add a small amount of isopropyl alcohol around the sides of the battery to soften the adhesive.
    • Take care to not get isopropyl alcohol on any other parts of the phone.
  6. Alcatel One Touch Idol 3 Battery Replacement: 步骤 6 中的图像 1,3 Alcatel One Touch Idol 3 Battery Replacement: 步骤 6 中的图像 2,3 Alcatel One Touch Idol 3 Battery Replacement: 步骤 6 中的图像 3,3
    • Pry out the battery by leveraging an object under the battery and lifting it upwards.
    • Although a razor is depicted, we recommend using ESD-safe pry tools instead. A razor could easily puncture the battery and create a hazard.
结论
Eric Lopez
于10/31/23注册
133 声望
撰写一个指南
团队
CSU Los Angeles, Team 2-87, Briggs Fall 2023 CSU Los Angeles, Team 2-87, Briggs Fall 2023 的会员
CSULA-BRIGGS-F23S2G87
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 101
