跳转到主内容
Alcatel One Touch Fierce Front Facing Camera Replacement
你所需要的
  1. Alcatel One Touch Fierce Front Facing Camera Replacement, Rear Case: 步骤 1 中的图像 1,2 Alcatel One Touch Fierce Front Facing Camera Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Pry with a plastic opening tool, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Alcatel One Touch Fierce Front Facing Camera Replacement, Midframe: 步骤 2 中的图像 1,3 Alcatel One Touch Fierce Front Facing Camera Replacement, Midframe: 步骤 2 中的图像 2,3 Alcatel One Touch Fierce Front Facing Camera Replacement, Midframe: 步骤 2 中的图像 3,3
    • Remove the 11 Phillips #000 screws.
    • The midframe should lift free.
  3. Alcatel One Touch Fierce Front Facing Camera Replacement, Battery: 步骤 3 中的图像 1,2 Alcatel One Touch Fierce Front Facing Camera Replacement, Battery: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use the tip of a spudger to pull back the yellow tape covering the battery connector.
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
  4. Alcatel One Touch Fierce Front Facing Camera Replacement, Camera: 步骤 4 中的图像 1,1
    • Carefully remove the motherboard from the rest of the phone.
  5. Alcatel One Touch Fierce Front Facing Camera Replacement: 步骤 5 中的图像 1,2 Alcatel One Touch Fierce Front Facing Camera Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to disconnect and remove the front facing camera from the motherboard.
结论
5等其他人完成本指南。
团队
UMass Dartmouth, Team 5-5, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-5, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S5G5
3 名成员
创作了6篇指南
2条评论
tenx tenx tenx !!?
ismail - 回复
I paid for a phone to capture precious moments, & the pictures are horrible, how can this be fixed??? This is wrong on all levels, I feel that we should be able to try any phone out before purchasing, so we know what we are buying, I'm returning my phone & wouldn't recommend this brand to anyone.
Jeanne Edenfield - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 6,527
