跳转到主内容
Alcatel One Touch Evolve 2 Back Frame Replacement
你所需要的
  1. Alcatel One Touch Evolve 2 Back Frame Replacement, Back Frame: 步骤 1 中的图像 1,3 Alcatel One Touch Evolve 2 Back Frame Replacement, Back Frame: 步骤 1 中的图像 2,3 Alcatel One Touch Evolve 2 Back Frame Replacement, Back Frame: 步骤 1 中的图像 3,3
    • Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents.
    • Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
    • Be gentle when prying so as to not wear out the tool.
  2. Alcatel One Touch Evolve 2 Back Frame Replacement: 步骤 2 中的图像 1,1
    • Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
  3. Alcatel One Touch Evolve 2 Back Frame Replacement: 步骤 3 中的图像 1,1
    • Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
  4. Alcatel One Touch Evolve 2 Back Frame Replacement: 步骤 4 中的图像 1,3 Alcatel One Touch Evolve 2 Back Frame Replacement: 步骤 4 中的图像 2,3 Alcatel One Touch Evolve 2 Back Frame Replacement: 步骤 4 中的图像 3,3
    • Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
  5. Alcatel One Touch Evolve 2 Back Frame Replacement: 步骤 5 中的图像 1,2 Alcatel One Touch Evolve 2 Back Frame Replacement: 步骤 5 中的图像 2,2
    • Pull the rear frame off with your hands.
结论
Andrew Bai
于01/30/17注册
634 声望
创作了5篇指南
团队
IUPUI, Team 1-3, Baechle Spring 2017 IUPUI, Team 1-3, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S1G3
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 943
