跳转到主内容
Alcatel IdealXCITE Rear Speaker Replacement
你所需要的
  1. Alcatel IdealXCITE Rear Speaker Replacement, Battery: 步骤 1 中的图像 1,3 Alcatel IdealXCITE Rear Speaker Replacement, Battery: 步骤 1 中的图像 2,3 Alcatel IdealXCITE Rear Speaker Replacement, Battery: 步骤 1 中的图像 3,3
    • Place your finger in the small notch on the left corner of the phone.
    • Use your finger to gently pull up on the back cover where the notch is located.
    • Gently pull up on the back cover, working around the phone.
    • Remove the cover from the phone, and set it aside for later installation.
  2. Alcatel IdealXCITE Rear Speaker Replacement: 步骤 2 中的图像 1,3 Alcatel IdealXCITE Rear Speaker Replacement: 步骤 2 中的图像 2,3 Alcatel IdealXCITE Rear Speaker Replacement: 步骤 2 中的图像 3,3
    • Place your thumb in the small notch between the battery and the phone.
    • Use your thumb to gently pry the battery up at the notch, releasing it from the phone.
    • Take note of the contacts in the phone and on the battery for reinstallation.
  3. Alcatel IdealXCITE Rear Speaker Replacement, Antenna: 步骤 3 中的图像 1,2 Alcatel IdealXCITE Rear Speaker Replacement, Antenna: 步骤 3 中的图像 2,2
    • Remove the four 4mm PH00 screws.
  4. Alcatel IdealXCITE Rear Speaker Replacement: 步骤 4 中的图像 1,3 Alcatel IdealXCITE Rear Speaker Replacement: 步骤 4 中的图像 2,3 Alcatel IdealXCITE Rear Speaker Replacement: 步骤 4 中的图像 3,3
    • Using a spudger, pry upwards in the indentation on the bottom right corner of the phone.
    • Work the tool gently around the antenna to release it.
  5. Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: 步骤 5 中的图像 1,3 Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: 步骤 5 中的图像 2,3 Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: 步骤 5 中的图像 3,3
    • Remove the three 4mm PH00 screws holding the WiFi/GPS antenna in.
    • Gently pry the WiFi/GPS antenna out using a Jimmy and set aside.
  6. Alcatel IdealXCITE Rear Speaker Replacement: 步骤 6 中的图像 1,2 Alcatel IdealXCITE Rear Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the three remaining 4mm PH00 screws.
    • Remove the two 3mm PH00 screws.
  7. Alcatel IdealXCITE Rear Speaker Replacement: 步骤 7 中的图像 1,3 Alcatel IdealXCITE Rear Speaker Replacement: 步骤 7 中的图像 2,3 Alcatel IdealXCITE Rear Speaker Replacement: 步骤 7 中的图像 3,3
    • Using a spudger and an iFixit opening pick, pry the midframe up.
  8. Alcatel IdealXCITE Rear Speaker Replacement: 步骤 8 中的图像 1,3 Alcatel IdealXCITE Rear Speaker Replacement: 步骤 8 中的图像 2,3 Alcatel IdealXCITE Rear Speaker Replacement: 步骤 8 中的图像 3,3
    • Pry gently between the rear case and speaker using an iFixit opening pick.
    • Reapply adhesive to the new speaker when reassembling the phone.
结论
Franklin Froehlich
于03/07/19注册
427 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 292
