跳转到主内容
Alcatel IdealXCITE Battery Replacement
你所需要的
  1. Alcatel IdealXCITE Battery Replacement, Battery: 步骤 1 中的图像 1,3 Alcatel IdealXCITE Battery Replacement, Battery: 步骤 1 中的图像 2,3 Alcatel IdealXCITE Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Place your finger in the small notch on the left corner of the phone.
    • Use your finger to gently pull up on the back cover where the notch is located.
    • Gently pull up on the back cover, working around the phone.
    • Remove the cover from the phone, and set it aside for later installation.
  2. Alcatel IdealXCITE Battery Replacement: 步骤 2 中的图像 1,3 Alcatel IdealXCITE Battery Replacement: 步骤 2 中的图像 2,3 Alcatel IdealXCITE Battery Replacement: 步骤 2 中的图像 3,3
    • Place your thumb in the small notch between the battery and the phone.
    • Use your thumb to gently pry the battery up at the notch, releasing it from the phone.
    • Take note of the contacts in the phone and on the battery for reinstallation.
结论
In order to reassemble your device, follow the instructions in reverse order.
Franklin Froehlich
于03/07/19注册
427 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 445
