跳转到主内容
Alcatel IdealXCITE Antenna Replacement
你所需要的
  1. Alcatel IdealXCITE Antenna Replacement, Battery: 步骤 1 中的图像 1,3 Alcatel IdealXCITE Antenna Replacement, Battery: 步骤 1 中的图像 2,3 Alcatel IdealXCITE Antenna Replacement, Battery: 步骤 1 中的图像 3,3
    • Place your finger in the small notch on the left corner of the phone.
    • Use your finger to gently pull up on the back cover where the notch is located.
    • Gently pull up on the back cover, working around the phone.
    • Remove the cover from the phone, and set it aside for later installation.
  2. Alcatel IdealXCITE Antenna Replacement: 步骤 2 中的图像 1,3 Alcatel IdealXCITE Antenna Replacement: 步骤 2 中的图像 2,3 Alcatel IdealXCITE Antenna Replacement: 步骤 2 中的图像 3,3
    • Place your thumb in the small notch between the battery and the phone.
    • Use your thumb to gently pry the battery up at the notch, releasing it from the phone.
    • Take note of the contacts in the phone and on the battery for reinstallation.
  3. Alcatel IdealXCITE Antenna Replacement, Antenna: 步骤 3 中的图像 1,2 Alcatel IdealXCITE Antenna Replacement, Antenna: 步骤 3 中的图像 2,2
    • Remove the four 4mm PH00 screws.
  4. Alcatel IdealXCITE Antenna Replacement: 步骤 4 中的图像 1,3 Alcatel IdealXCITE Antenna Replacement: 步骤 4 中的图像 2,3 Alcatel IdealXCITE Antenna Replacement: 步骤 4 中的图像 3,3
    • Using a spudger, pry upwards in the indentation on the bottom right corner of the phone.
    • Work the tool gently around the antenna to release it.
结论
Franklin Froehlich
于03/07/19注册
427 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 589
