跳转到主内容
Alcatel Go Flip V Flip Phone Motherboard Replacement
你所需要的
  1. Alcatel Go Flip V Flip Phone Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Alcatel Go Flip V Flip Phone Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Alcatel Go Flip V Flip Phone Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
    • The battery cover provides a notch to use in levering the cover off.
    • Place your thumbnail in the notch and pry up.
    • Here you can see the back starting to separate.
  2. Alcatel Go Flip V Flip Phone Motherboard Replacement: 步骤 2 中的图像 1,1
    • The rear cover has been removed.
  3. Alcatel Go Flip V Flip Phone Motherboard Replacement: 步骤 3 中的图像 1,3 Alcatel Go Flip V Flip Phone Motherboard Replacement: 步骤 3 中的图像 2,3 Alcatel Go Flip V Flip Phone Motherboard Replacement: 步骤 3 中的图像 3,3
    • The midframe has a cutout for a fingernail to use to remove the battery.
    • Use your fingernail to pry the battery up and lift it out.
  4. Alcatel Go Flip V Flip Phone Motherboard Replacement: 步骤 4 中的图像 1,1
    • The battery has been removed.
  5. Alcatel Go Flip V Flip Phone Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,2 Alcatel Go Flip V Flip Phone Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Remove the eight 4.25mm Phillips screws securing the midframe.
  6. Alcatel Go Flip V Flip Phone Motherboard Replacement, Remove the Midframe: 步骤 6 中的图像 1,3 Alcatel Go Flip V Flip Phone Motherboard Replacement, Remove the Midframe: 步骤 6 中的图像 2,3 Alcatel Go Flip V Flip Phone Motherboard Replacement, Remove the Midframe: 步骤 6 中的图像 3,3
    • Starting at the top, insert a pry tool under the midframe.
    • Proceed down both sides, releasing the clips holding the midframe on.
    • Then you can lift the midframe from the phone.
  7. Alcatel Go Flip V Flip Phone Motherboard Replacement: 步骤 7 中的图像 1,1
    • The midframe has been removed.
  8. Alcatel Go Flip V Flip Phone Motherboard Replacement, Unplug the Display Connector: 步骤 8 中的图像 1,3 Alcatel Go Flip V Flip Phone Motherboard Replacement, Unplug the Display Connector: 步骤 8 中的图像 2,3 Alcatel Go Flip V Flip Phone Motherboard Replacement, Unplug the Display Connector: 步骤 8 中的图像 3,3
    • Use a spudger to unplug the display connector.
  9. Alcatel Go Flip V Flip Phone Motherboard Replacement, Remove the Motherboard/Keypad Assembly: 步骤 9 中的图像 1,3 Alcatel Go Flip V Flip Phone Motherboard Replacement, Remove the Motherboard/Keypad Assembly: 步骤 9 中的图像 2,3 Alcatel Go Flip V Flip Phone Motherboard Replacement, Remove the Motherboard/Keypad Assembly: 步骤 9 中的图像 3,3
    • Open the phone and press the keyboard/motherboard assembly out from the front.
  10. Alcatel Go Flip V Flip Phone Motherboard Replacement: 步骤 10 中的图像 1,2 Alcatel Go Flip V Flip Phone Motherboard Replacement: 步骤 10 中的图像 2,2
    • Remove the motherboard.
结论
Jerry Wheeler
于03/21/22注册
72,157 声望
创作了71篇指南
团队
Oregonians Oregonians 的会员
Community
8 名成员
创作了189篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 20
总计 253
