跳转到主内容
Alcatel Go Flip V Flip Phone Camera Replacement
你所需要的
  1. Alcatel Go Flip V Flip Phone Camera Replacement, Remove the Screen Cover: 步骤 1 中的图像 1,1
    • Heat the screen cover with an iOpener, a heat gun or even a hair dryer to soften the adhesive holding it to the display frame.
    • Use caution with a heat gun as you could easily melt the plastic screen cover.
  2. Alcatel Go Flip V Flip Phone Camera Replacement: 步骤 2 中的图像 1,2 Alcatel Go Flip V Flip Phone Camera Replacement: 步骤 2 中的图像 2,2
    • Insert a curved razor blade under the screen cover to pry it open.
  3. Alcatel Go Flip V Flip Phone Camera Replacement: 步骤 3 中的图像 1,2 Alcatel Go Flip V Flip Phone Camera Replacement: 步骤 3 中的图像 2,2
    • Use plastic picks to separate the adhesive. Metal is not advised as it will scratch the plastic material the cover is made of. Add more heat as needed.
  4. Alcatel Go Flip V Flip Phone Camera Replacement: 步骤 4 中的图像 1,2 Alcatel Go Flip V Flip Phone Camera Replacement: 步骤 4 中的图像 2,2
    • Remove the plastic screen cover.
  5. Alcatel Go Flip V Flip Phone Camera Replacement, Remove the Rear Cover: 步骤 5 中的图像 1,2 Alcatel Go Flip V Flip Phone Camera Replacement, Remove the Rear Cover: 步骤 5 中的图像 2,2
    • Remove the four 3.5mm Phillips screws holding the rear cover in place.
  6. Alcatel Go Flip V Flip Phone Camera Replacement: 步骤 6 中的图像 1,3 Alcatel Go Flip V Flip Phone Camera Replacement: 步骤 6 中的图像 2,3 Alcatel Go Flip V Flip Phone Camera Replacement: 步骤 6 中的图像 3,3
    • Starting at the hinge side, insert a metal opening tool between the rear cover and the display's frame.
    • Continue down the side of the phone, releasing clips as you go.
  7. Alcatel Go Flip V Flip Phone Camera Replacement: 步骤 7 中的图像 1,3 Alcatel Go Flip V Flip Phone Camera Replacement: 步骤 7 中的图像 2,3 Alcatel Go Flip V Flip Phone Camera Replacement: 步骤 7 中的图像 3,3
    • Work your way across the bottom and up the other side.
    • And finally the rear cover is free.
  8. Alcatel Go Flip V Flip Phone Camera Replacement, Remove the Camera: 步骤 8 中的图像 1,2 Alcatel Go Flip V Flip Phone Camera Replacement, Remove the Camera: 步骤 8 中的图像 2,2
    • Using a spudger, disconnect the camera's flex cable.
  9. Alcatel Go Flip V Flip Phone Camera Replacement: 步骤 9 中的图像 1,2 Alcatel Go Flip V Flip Phone Camera Replacement: 步骤 9 中的图像 2,2
    • Remove the camera from the display.
结论
Jerry Wheeler
于03/21/22注册
72,157 声望
创作了71篇指南
团队
Oregonians Oregonians 的会员
Community
8 名成员
创作了189篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 64
