跳转到主内容
Akko 3068B Battery Replacement
你所需要的
  1. Akko 3068B Battery Replacement, Battery: 步骤 1 中的图像 1,3 Akko 3068B Battery Replacement, Battery: 步骤 1 中的图像 2,3 Akko 3068B Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the USB-C cable from the keyboard.
    • Turn off keyboard using the switch on the back.
  2. Akko 3068B Battery Replacement: 步骤 2 中的图像 1,2 Akko 3068B Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the keycaps using a keycap puller.
    • Removing them without thought can accidentally damage the switches on the keyboard. Proceed with caution.
  3. Akko 3068B Battery Replacement: 步骤 3 中的图像 1,3 Akko 3068B Battery Replacement: 步骤 3 中的图像 2,3 Akko 3068B Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the three screws holding the PCB in place using a Phillips #00 screwdriver.
  4. Akko 3068B Battery Replacement: 步骤 4 中的图像 1,3 Akko 3068B Battery Replacement: 步骤 4 中的图像 2,3 Akko 3068B Battery Replacement: 步骤 4 中的图像 3,3
    • Insert a card to pry open the casing on the keyboard.
    • When prying open the casing, beware that there are clips that lock the casing to the keyboard. Make sure not to break them or the casing will not lock properly afterwards.
    • A small clear piece might fall out near the keyboard lights; make sure to place it back when reassembling.
  5. Akko 3068B Battery Replacement: 步骤 5 中的图像 1,3 Akko 3068B Battery Replacement: 步骤 5 中的图像 2,3 Akko 3068B Battery Replacement: 步骤 5 中的图像 3,3
    • Careful! If the keyboard is old, the PCB might just fall out.
    • Slowly lift up the PCB as there is a connector on the back; make sure not to rip it apart.
  6. Akko 3068B Battery Replacement: 步骤 6 中的图像 1,1
    • Lift up the sound proof foam.
  7. Akko 3068B Battery Replacement: 步骤 7 中的图像 1,2 Akko 3068B Battery Replacement: 步骤 7 中的图像 2,2
    • Slowly wiggle the battery wire out of its connector on the motherboard.
    • If too much strength is applied, you can rip off the port.
  8. Akko 3068B Battery Replacement: 步骤 8 中的图像 1,1
    • Remove the battery from the keyboard.
    • Make sure that the new battery is compatible. This is a 1800 mah battery.
结论
Dylan Tran
于01/23/24注册
157 声望
撰写一个指南
团队
1指南评论
I can confirm the the same/similar steps can be taken to remove/change the battery on "Black & Gold 5108B Plus ISO DE/UK/Nordic" keyboard.
Thank you for your guide.
Juraj - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 30
过去 30 天: 149
总计 2,133
