跳转到主内容
Akaso EK7000 4K Microphone Replacement
你所需要的
  1. Akaso EK7000 4K Microphone Replacement, Battery: 步骤 1 中的图像 1,2 Akaso EK7000 4K Microphone Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the battery cover at the bottom of the camera. Use your fingers to gently pry open the battery cover.
  2. Akaso EK7000 4K Microphone Replacement: 步骤 2 中的图像 1,2 Akaso EK7000 4K Microphone Replacement: 步骤 2 中的图像 2,2
    • Locate the small plastic flap attached to the battery. Pull the battery out towards you.
  3. Akaso EK7000 4K Microphone Replacement, Front Panel: 步骤 3 中的图像 1,2 Akaso EK7000 4K Microphone Replacement, Front Panel: 步骤 3 中的图像 2,2
    • Using the metal spudger, gently pry open the front panel from the exposed battery cartridge.
  4. Akaso EK7000 4K Microphone Replacement: 步骤 4 中的图像 1,2 Akaso EK7000 4K Microphone Replacement: 步骤 4 中的图像 2,2
    • Remove the rest of front panel with your fingers or with assistance from the spudger.
  5. Akaso EK7000 4K Microphone Replacement, Microphone: 步骤 5 中的图像 1,2 Akaso EK7000 4K Microphone Replacement, Microphone: 步骤 5 中的图像 2,2
    • After removing the front panel, make sure that the battery is also removed from the camera battery cartridge to continue.
  6. Akaso EK7000 4K Microphone Replacement: 步骤 6 中的图像 1,2 Akaso EK7000 4K Microphone Replacement: 步骤 6 中的图像 2,2
    • When observing the camera plate under the front panel, notice that there are four screws holding the camera plate in place.
    • Use a Phillips #000 screwdriver to remove all four screws.
  7. Akaso EK7000 4K Microphone Replacement: 步骤 7 中的图像 1,2 Akaso EK7000 4K Microphone Replacement: 步骤 7 中的图像 2,2
    • Insert a thumb into the battery cartridge and gently push up. Be careful as not to pull apart or break any of the wiring that connects the front plate to the LED screen. The microphone will be on the left bottom corner of the front panel.
    • Gently pull out the microphone. Now you can re-adjust or replace the microphone.
结论
另外一个人完成了本指南。
Katrina Shi
于02/06/19注册
166 声望
撰写一个指南
团队
UC Davis, Team S20-G2, Lore Winter 2019 UC Davis, Team S20-G2, Lore Winter 2019 的会员
UCD-LORE-W19S20G2
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 32
总计 2,734
