跳转到主内容
Akaso EK7000 4K Button Replacement
你所需要的
  1. Akaso EK7000 4K Button Replacement, Battery: 步骤 1 中的图像 1,2 Akaso EK7000 4K Button Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the battery cover at the bottom of the camera. Use your fingers to gently pry open the battery cover.
  2. Akaso EK7000 4K Button Replacement: 步骤 2 中的图像 1,2 Akaso EK7000 4K Button Replacement: 步骤 2 中的图像 2,2
    • Locate the small plastic flap attached to the battery. Pull the battery out towards you.
  3. Akaso EK7000 4K Button Replacement, Front Panel: 步骤 3 中的图像 1,2 Akaso EK7000 4K Button Replacement, Front Panel: 步骤 3 中的图像 2,2
    • Using the metal spudger, gently pry open the front panel from the exposed battery cartridge.
  4. Akaso EK7000 4K Button Replacement: 步骤 4 中的图像 1,2 Akaso EK7000 4K Button Replacement: 步骤 4 中的图像 2,2
    • Remove the rest of front panel with your fingers or with assistance from the spudger.
  5. Akaso EK7000 4K Button Replacement, Button: 步骤 5 中的图像 1,2 Akaso EK7000 4K Button Replacement, Button: 步骤 5 中的图像 2,2
    • Using a Phillips #000 screwdriver, remove the four screws securing the cover plate.
  6. Akaso EK7000 4K Button Replacement: 步骤 6 中的图像 1,2 Akaso EK7000 4K Button Replacement: 步骤 6 中的图像 2,2
    • Using your thumb or a spudger, gently push up from inside the battery cartridge.
    • Gently lift the cover plate until you can see into the inside of the camera. The cover will not completely come off, so be careful not to damage any of the inner wiring.
  7. Akaso EK7000 4K Button Replacement: 步骤 7 中的图像 1,2 Akaso EK7000 4K Button Replacement: 步骤 7 中的图像 2,2
    • Using the metal spudger, push down on the up and down button as shown in the picture. Dislodge the button and it should fall to the bottom of the camera.
  8. Akaso EK7000 4K Button Replacement: 步骤 8 中的图像 1,2 Akaso EK7000 4K Button Replacement: 步骤 8 中的图像 2,2
    • Again, using the metal spudger, gently pull out the button from within the camera.
结论
2等其他人完成本指南。
Annie Sun
于02/05/19注册
436 声望
创作了3篇指南
团队
UC Davis, Team S20-G2, Lore Winter 2019 UC Davis, Team S20-G2, Lore Winter 2019 的会员
UCD-LORE-W19S20G2
3 名成员
创作了4篇指南
3条评论
Annie, where do I get the replacemnet bottons for the Akaso 7000 pro?
ecab110544 - 回复
I need a replacement top button. Plastic got messed up but was able to still press the metallic part. But didn't realize it wasn't secure and it fell off at some point. Can start recording by shorting across contacts but looking for a fix.
Mark - 回复
Who is going to answer above questions?
luis - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 41
总计 2,236
