跳转到主内容
Akaso EK7000 4K Battery Replacement
  1. Akaso EK7000 4K Battery Replacement, Battery: 步骤 1 中的图像 1,2 Akaso EK7000 4K Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the battery cover at the bottom of the camera. Use your fingers to gently pry open the battery cover.
  2. Akaso EK7000 4K Battery Replacement: 步骤 2 中的图像 1,2 Akaso EK7000 4K Battery Replacement: 步骤 2 中的图像 2,2
    • Locate the small plastic flap attached to the battery. Pull the battery out towards you.
结论
6等其他人完成本指南。
Annie Sun
于02/05/19注册
436 声望
创作了3篇指南
团队
UC Davis, Team S20-G2, Lore Winter 2019 UC Davis, Team S20-G2, Lore Winter 2019 的会员
UCD-LORE-W19S20G2
3 名成员
创作了4篇指南
2条评论
Thank you for the help actclly needed that help
Charisma Broughton - 回复
I’ve been using my Akaso EK7000 Pro as a dashcam, I removed the battery and plugged the camera into the cars cigar lighter, now when I insert the battery the cover won’t go back on.
The battery will push down into place but when I let go to put the cover on the battery moves up and the cover is about one tenth of one millimetre too high to fit.
The camera does get quite warm when in use and I suspect the plastic of the battery chamber has slightly distorted preventing the battery going fully into it and allowing the cover to be put into place.
Do you have any suggestions how I can resolve this issue?
Glynn Sole - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 15
过去 30 天: 40
总计 4,513
