跳转到主内容
Akai MPK25 Keys Replacement
你所需要的
  1. Akai MPK25 Keys Replacement, Face Plate: 步骤 1 中的图像 1,1
    • Remove all the selector knob covers by pulling them off.
  2. Akai MPK25 Keys Replacement: 步骤 2 中的图像 1,1
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
  3. Akai MPK25 Keys Replacement: 步骤 3 中的图像 1,1
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
  4. Akai MPK25 Keys Replacement: 步骤 4 中的图像 1,3 Akai MPK25 Keys Replacement: 步骤 4 中的图像 2,3 Akai MPK25 Keys Replacement: 步骤 4 中的图像 3,3
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
  5. Akai MPK25 Keys Replacement: 步骤 5 中的图像 1,3 Akai MPK25 Keys Replacement: 步骤 5 中的图像 2,3 Akai MPK25 Keys Replacement: 步骤 5 中的图像 3,3
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
  6. Akai MPK25 Keys Replacement, Keys: 步骤 6 中的图像 1,2 Akai MPK25 Keys Replacement, Keys: 步骤 6 中的图像 2,2
    • Using needle nose pliers, grip the top of the spring coil, that is holding down the key, and gently lift the spring away from the key.
  7. Akai MPK25 Keys Replacement: 步骤 7 中的图像 1,1
    • Lift the key from the front of the keyboard towards the back in order to remove it completely.
结论
To reassemble the keyboard and close up the case, follow these instructions in reverse order.
7等其他人完成本指南。
Will Saba
于01/11/13注册
412 声望
创作了2篇指南
团队
Cal Poly, Team 20-6, Maness Winter 2013 Cal Poly, Team 20-6, Maness Winter 2013 的会员
CPSU-MANESS-W13S20G6
5 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 29
总计 11,564
