跳转到主内容
Akai MPK25 Face Plate Replacement
你所需要的
  1. Akai MPK25 Face Plate Replacement, Face Plate: 步骤 1 中的图像 1,1
    • Remove all the selector knob covers by pulling them off.
  2. Akai MPK25 Face Plate Replacement: 步骤 2 中的图像 1,1
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
  3. Akai MPK25 Face Plate Replacement: 步骤 3 中的图像 1,1
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
  4. Akai MPK25 Face Plate Replacement: 步骤 4 中的图像 1,3 Akai MPK25 Face Plate Replacement: 步骤 4 中的图像 2,3 Akai MPK25 Face Plate Replacement: 步骤 4 中的图像 3,3
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
  5. Akai MPK25 Face Plate Replacement: 步骤 5 中的图像 1,3 Akai MPK25 Face Plate Replacement: 步骤 5 中的图像 2,3 Akai MPK25 Face Plate Replacement: 步骤 5 中的图像 3,3
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 20-6, Maness Winter 2013 Cal Poly, Team 20-6, Maness Winter 2013 的会员
CPSU-MANESS-W13S20G6
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,614
