跳转到主内容
Airox Legendair Turbine Box Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. Airox Legendair Turbine Box Replacement, How to Properly Clean the Airox Legendair: 步骤 1 中的图像 1,1
    • First, switch off the device.
    • Place the device in a clean and open environment.
  2. Airox Legendair Turbine Box Replacement: 步骤 3 中的图像 1,1
    • Using a cloth or a sponge slightly dampened with a bactericide or germicide solution, gently clean the outside of the device.
  3. Airox Legendair Turbine Box Replacement: 步骤 4 中的图像 1,1
    • If necessary, spray the device lightly with the germicide solution, taking account of the requirements discussed in the preliminary operations.
    • Do not allow any liquid to enter inside the device (in particular through the cooling apertures).
    • Use a gentle air blast to clear away any remaining liquid from ventilator.
  4. Airox Legendair Turbine Box Replacement, Turbine Box: 步骤 6 中的图像 1,1
    • Make sure to turn off the ventilator before starting the repair.
    • Put the device in a clean and open environment.
    • Thoroughly clean the device before beginning any work.
  5. Airox Legendair Turbine Box Replacement: 步骤 7 中的图像 1,1
    • Open the device by removing the five attachment screws (Pl1.20) on the bottom casing side (Pl1-280). Lift off the top outer panel.
    • Carefully separate the two casings to avoid tearing off the keypad connections.
  6. Airox Legendair Turbine Box Replacement: 步骤 8 中的图像 1,1
    • Unscrew the three attachment screws (Pl1-130) for the CPU board (Pl1-120).
  7. Airox Legendair Turbine Box Replacement: 步骤 9 中的图像 1,1
    • Disconnect all connectors Pl1.J1.CT, Pl1.J2.CT of the turbine control board.
  8. Airox Legendair Turbine Box Replacement: 步骤 10 中的图像 1,1
    • Extract the turbine casing (Pl1.50) from its housing and uncouple the flow rate measurement block (Pl1-260), the O2 supply pipes and the piezo solenoid valve.
  9. Airox Legendair Turbine Box Replacement: 步骤 11 中的图像 1,1
    • Place the turbine box (Pl1-50) in a clean and open environment
    • Remove the four screws, washers and spacers (Pl1.70, Pl1.80, Pl1.90) in order to successfully extract the turbine control board (Pl1.60).
  10. Airox Legendair Turbine Box Replacement: 步骤 12 中的图像 1,1
    • Disconnect the box from the turbine control board (Pl1.J6.CT).
  11. Airox Legendair Turbine Box Replacement: 步骤 13 中的图像 1,1
    • Replace the turbine box (Pl1-50).
    • Replace the turbine control board (Pl1.60) on the box with four screws, washers and spacers (Pl1.70, Pl1.80, Pl1.90) (Torque 5 Nm max.).
  12. Airox Legendair Turbine Box Replacement: 步骤 14 中的图像 1,2 Airox Legendair Turbine Box Replacement: 步骤 14 中的图像 2,2
    • Connect the box to the turbine control board (Pl1.J6.CT).
    • Couple the flow rate measurement block (Pl1-260) to the casing and connect the two O2 supply pipes and the piezo solenoid valve.
    • Then, reinsert the assembly into its housing. Put the cone support (Pl1-50) into place. Put the additional cone support (Pl1-220) also into place.
  13. Airox Legendair Turbine Box Replacement: 步骤 15 中的图像 1,1
    • Reconnect all connectors (Pl1.J1.CT, Pl1.J2.CT) to the turbine control board.
  14. Airox Legendair Turbine Box Replacement: 步骤 16 中的图像 1,1
    • Reinstall the CPU board (Pl1-120) with the three attachment screws (Pl1-130) (Torque 5 Nm max.)
    • Close the device again, taking all necessary precautions (see Step 2-3)
结论
Perform a final inspection of the device before putting back into service.
另外一个人完成了本指南。
Noah Clark
于04/09/20注册
243 声望
撰写一个指南
团队
Cal Poly, Team S7-G15, Paton Spring 2020 Cal Poly, Team S7-G15, Paton Spring 2020 的会员
CPSU-PATON-S20S7G15
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 248
