跳转到主内容
Airox Legendair Battery Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. Airox Legendair Battery Replacement, How to Properly Clean the Airox Legendair: 步骤 1 中的图像 1,1
    • First, switch off the device.
    • Place the device in a clean and open environment.
  2. Airox Legendair Battery Replacement: 步骤 3 中的图像 1,1
    • Using a cloth or a sponge slightly dampened with a bactericide or germicide solution, gently clean the outside of the device.
  3. Airox Legendair Battery Replacement: 步骤 4 中的图像 1,1
    • If necessary, spray the device lightly with the germicide solution, taking account of the requirements discussed in the preliminary operations.
    • Do not allow any liquid to enter inside the device (in particular through the cooling apertures).
    • Use a gentle air blast to clear away any remaining liquid from ventilator.
  4. Airox Legendair Battery Replacement, Battery: 步骤 6 中的图像 1,1
    • Make sure to turn off the ventilator before starting the repair.
    • Before you start the battery replacement process, make sure that the device has been placed in a clean and open environment.
  5. Airox Legendair Battery Replacement: 步骤 7 中的图像 1,1
    • Remove each attachment screw from the battery cover.
  6. Airox Legendair Battery Replacement: 步骤 8 中的图像 1,1
    • Remove the battery cover carefully by holding the rails and pulling toward the rear of the device.
  7. Airox Legendair Battery Replacement: 步骤 9 中的图像 1,1
    • Extract the current battery and replace it with the new battery.
  8. Airox Legendair Battery Replacement: 步骤 10 中的图像 1,1
    • Confirm that all elements line up together. Then, reattach the battery cover with the attachment screws that were removed in Step 2.
  9. Airox Legendair Battery Replacement: 步骤 11 中的图像 1,1
    • Switch the device to "Set Up Mode" by pressing the On/Off switch.
    • Hold the menu key until the menu options appear on the screen.
    • Select the "MAINTENANCE" option with cursor.
    • Select "Voltage control" and verify that the voltage of the battery is 28.5±1V.
结论
Perform the final inspection procedures by confirming that every screw is secure before putting back into service.
Caleb Erlenborn
于04/09/20注册
174 声望
撰写一个指南
团队
Cal Poly, Team S7-G15, Paton Spring 2020 Cal Poly, Team S7-G15, Paton Spring 2020 的会员
CPSU-PATON-S20S7G15
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 9
总计 340
