简介
Replacing the fan on the AirPort Extreme A1521 requires a fair amount of disassembly; note that there are many small screws to keep track of. The fan keeps the device from overheating while in use.
配件
没有特定配件。
Using a metal spudger, gently pry the cover off the bottom of the device.
To detach the small clips from the connectors, place the flat end of the plastic spudger underneath the clip and gently lever it away from the center of the device.
To detach the large clip from its connector, place the flat end of the spudger on the clip and lever it upward out of the connector.
53等其他人完成本指南。
15条评论
Thanks for the guide. My 4-year old A1521 gave me a flash warning light. I fired up the utility app and it said the device was overheating. I put my ear against it and couldn’t hear any noise. I opened it up as shown here, removed the outer casing and powered it up, confirming the cooling fan was not spinning. I found quite a bit of resistance when I turned the fan by my finger. I had some 0W-40 fully synthetic motor oil laying around. I opened the fan up just by pulling the fan blade unit up and lubricated the shaft with the motor oil. And it worked out beautifully. The fan spins quietly and I get my green light back.
I should say the most tricky part was the step 1. I used a dinner table knife to open the base. Later in the process I did break a fan shroud clip. But the fan was hold tightly together with the screws in the end so it didn’t do any actual damage. It wasn’t a particular hot day, but without the fan the device did become warm and the internet speed was noticeably slowed down.
does anyone know of a good place to get a replacement fan (AirPort Extreme A1521 Fan Replacement)? Any insight is greatly appreciated.
Yes I`m also interested in a replacement fan
You can find replacement fan on ebay. The part is labeled as BSB0712HC-HM01 and it costs about 24 USD. Before replacing try oiling the shaft of the fan (pull it up straight! - oil the shaft, not the mechanism!) - it worked for me.
Janez Ford - 回复
The manufacturer of the original OEM fan in my Airport Extreme is SUNON. It can be found on eBay. MG60121V1-CO1U-S9A is the part number on the one I extracted from my Airport. SUNON MagLev, DV12V, 4.20W.
