你所需要的
视频概述
要更换 AiPods Pro 的电池很有难度。首先需要一个专门的支架来分离外壳。此外,在除胶时,需要非常谨慎的来避免损坏柔性线缆。安装电池时,需要再次用粘合剂密封外壳来防止播放时产生噪音。
20等其他人完成本指南。
由衷感谢以下译者:
100%
StarChen正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
7指南评论
where we can buy this kit
Managed to do this without any kind of clamp. Just split the two halves carefully using fingers and then tape the earpiece down to hold in place for soldering etc.
If your airpod crackles/squeaks when using noise cancellation after replacing the battery, make sure the two halves are competely sealed together and add some more adhesive if not. Also try giving the vents a clean with some IPA. Should sort out the problem.
