视频概述
这个高级牙线盒看起来很眼熟,但是 Apple 觉得它比前代产品应该更贵 $40。以下是详细的规格信息:
单个AirPods 重 0.14 oz(4 g),充电盒重 1.41 oz(40 g)
单个AirPods 的三维是 0.65" × 0.71" × 1.59" (16.5 mm × 18.0 mm × 40.5 mm),充电盒的三维则是 1.74" × 0.84" × 2.11" (44.3 mm × 21.3 mm × 53.5 mm)
新的 H1 芯片支持了 Bluetooth 5
无线充电盒
支持了 "Hey Siri"
这种机加工的金属铰链看起来比上一代的要更坚固些,并且肯定附着有有粘合剂。
我们的下一步是拆解电池,但是电池的粘合剂似乎不同意。根据我们的判断,把热量调到 11 ,关注着电池的肿胀状态,病态交叉手指祈祷电池不会 Galaxy Note 7 那样对待我们。
我们竭尽所能,一个撬棒依然没法拆出电池,我们到了更多。
拆解完成!让我们把这些组装回来,同步它们来出点声音。
开个玩笑,这些都已经被拆开了。
这也就是说,结构上并不是完全没有提升——这些小东西在洗衣机里度过一段意外的旅程时可能幸存下来。但是我们知道 Apple 可以做得更好。
如果你喜欢壁纸,这里有一些额外的 X 光照片你可以打印出来贴在你的 AorPods 充电盒上。
由衷感谢以下译者:
88%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
21条评论
That shiny water repellent coating looks like conformal coating. Does helps but only to a certain degree.
Love the tear-down but could you also delve into the top magnets that pull/hold the airpods in their charging tube and also how they are magnetically aligned in the lid? My thoughts are that the rear lid magnets oppose each other so has to help hold the lid open but their opposing force is overcome when the front magnets are attracted and obviously have more leverage being further from the hinge to snap shut and hold the lid closed. To me, this is an ingeniously overlooked design aspect of the case using magnets rather than springs to create a spring-like effect.
You guessed correctly :) That’s exactly what’s happening.
Yeah, this is important. You can sort of see it here, but it’s covered up by some type of grill.
