跳转到主内容
AirCard 770S Back Case Replacement
你所需要的
  1. AirCard 770S Back Case Replacement, Back Case: 步骤 1 中的图像 1,1
    • Hold the device with an open corner available and facing you.
  2. AirCard 770S Back Case Replacement: 步骤 2 中的图像 1,1
    • Using your finger, pry open any of the four corners of the back case of your AirCard 770S, until you see the back case disconnect from the device.
  3. AirCard 770S Back Case Replacement: 步骤 3 中的图像 1,1
    • Lift open the back case and remove it from the device.
    • In order to put a new back case on, make sure to align the white nobs found on the back cover, so that you do not force the case on and cause any damage to the device.
结论
Caitlin Little
于10/08/18注册
437 声望
创作了3篇指南
团队
Marist, Team S1-G2, Chaterdon Fall 2018 Marist, Team S1-G2, Chaterdon Fall 2018 的会员
MARS-CHATERDON-F18S1G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 6
总计 182
