跳转到主内容
加入维修社区 - 创建账户
Air Jordan 1 Crease and Scuff Removal
你所需要的
  1. Air Jordan 1 Crease and Scuff Removal, Air Jordan 1 Crease and Scuff Removal: 步骤 1 中的图像 1,1
    • Unlace sneakers.
  2. Air Jordan 1 Crease and Scuff Removal: 步骤 2 中的图像 1,1
    • Stuff toe-box with paper towels until leather is stuffed to capacity.
  3. Air Jordan 1 Crease and Scuff Removal: 步骤 3 中的图像 1,1
    • Dampen a small towel.
    • Place damp towel across toe-box.
  4. Air Jordan 1 Crease and Scuff Removal: 步骤 4 中的图像 1,1
    • Using a flat iron, iron over the damp towel to remove toe-box creases.
  5. Air Jordan 1 Crease and Scuff Removal: 步骤 5 中的图像 1,1
    • Keep the towl on after ironing them to reduce odd cracks.
    • For best results, keep toe-box stuffed with paper towels until you're ready to wear.
  6. Air Jordan 1 Crease and Scuff Removal: 步骤 6 中的图像 1,1
    • Select Angelus Leather Paint that matches the original color of your shoes.
    • Using a small paint brush, paint over scuffs and scratches with their original color in thin, even coats.
    • Allow 20 minutes in between coats for paint to fully dry.
  7. Air Jordan 1 Crease and Scuff Removal: 步骤 7 中的图像 1,1
    • Re-lace sneakers.
结论
Once you've completed these steps, your shoes will be ready for wear.
27等其他人完成本指南。
6指南评论
This is the best repair guide in the world.
Mohammad Abdellatif - 回复 分享
i love this repair guide.
Best repair guide ever!
Lucas Beauchamp - 回复 分享
why and how because i have the all jordan but the only jordan that have a crease is the jordan 12
Azariea Ray - 回复 分享
Would this technique work on fearless zoom irridecent ? I know when I have had just a drop of water on then it looks oily almost like there is a fine coat of some sort on them
Brad May - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 110
过去 30 天: 325
总计 96,353
