跳转到主内容
Air Hog Smash Bots Controller Motherboard Replacement
你所需要的
  1. Air Hog Smash Bots Controller Motherboard Replacement, Front Panel: 步骤 1 中的图像 1,2 Air Hog Smash Bots Controller Motherboard Replacement, Front Panel: 步骤 1 中的图像 2,2
    • Take out your controller and access to the back of the controller.
  2. Air Hog Smash Bots Controller Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the screw on the battery lid. Using the Hex 4 socket and PH #0 bit, remove the 8 mm screw.
  3. Air Hog Smash Bots Controller Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the 2 AAA batteries.
  4. Air Hog Smash Bots Controller Motherboard Replacement: 步骤 4 中的图像 1,2 Air Hog Smash Bots Controller Motherboard Replacement: 步骤 4 中的图像 2,2
    • Using the Hex 4 socket and PH #0 bit, remove the four 8 mm screws on the panel.
  5. Air Hog Smash Bots Controller Motherboard Replacement: 步骤 5 中的图像 1,2 Air Hog Smash Bots Controller Motherboard Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to disconnect the front and back parts of the panel.
    • Some of the internal components may be displaced when opening the controller.
  6. Air Hog Smash Bots Controller Motherboard Replacement, Controller Motherboard: 步骤 6 中的图像 1,2 Air Hog Smash Bots Controller Motherboard Replacement, Controller Motherboard: 步骤 6 中的图像 2,2
    • Using the PH #0 bit, remove two 8 mm screws on the main board.
    • De-solder the LED wires from the motherboard.
    • Lift the motherboard with a spudger to remove it from the case.
结论
另外一个人完成了本指南。
Brittany Frecker
于02/08/16注册
542 声望
创作了4篇指南
团队
IUPUI, Team 1-1, Baechle Spring 2016 IUPUI, Team 1-1, Baechle Spring 2016 的会员
IUPUI-BAECHLE-S16S1G1
4 名成员
创作了14篇指南
一条评论
Hi,
Remot controller doesn't work.
Because my son used it into water.
So what should I do for fix it?
Thanks.
Ali Hori - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 162
