跳转到主内容
Air Blasters Tek Six Reload Slider Spring Replacement
你所需要的
  1. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: 步骤 1 中的图像 1,3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: 步骤 1 中的图像 2,3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: 步骤 1 中的图像 3,3
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: 步骤 2 中的图像 1,3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: 步骤 2 中的图像 2,3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: 步骤 2 中的图像 3,3
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: 步骤 3 中的图像 1,3 Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: 步骤 3 中的图像 2,3 Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: 步骤 3 中的图像 3,3
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: 步骤 4 中的图像 1,3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: 步骤 4 中的图像 2,3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: 步骤 4 中的图像 3,3
    • Carefully grab the metal pin keeping the air system and top spring, and slide it outwards. This will release the air system with the plunger completely.
  5. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw holding the top spring to reload slider: 步骤 5 中的图像 1,2 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw holding the top spring to reload slider: 步骤 5 中的图像 2,2
    • Using a screwdriver, remove the 7.5 mm phillips 00 screw holding the top spring to the reload slider.
结论
团队
USF Tampa, Team 3-1, Brown Fall 2014 USF Tampa, Team 3-1, Brown Fall 2014 的会员
USFT-BROWN-F14S3G1
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 434
