跳转到主内容
Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement
你所需要的
  1. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement, Lens Assembly: 步骤 1 中的图像 1,3 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement, Lens Assembly: 步骤 1 中的图像 2,3 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement, Lens Assembly: 步骤 1 中的图像 3,3
    • Remove the battery cover.
    • Remove the batteries.
  2. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 步骤 2 中的图像 1,1
    • Unscrew the three 4mm screws from the battery side of the device. Use a Phillips screw driver.
  3. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the four screws from the back side.
  4. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 步骤 4 中的图像 1,2 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 步骤 4 中的图像 2,2
    • Remove the sticky black dots.
    • Remove the hidden screw.
  5. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 步骤 5 中的图像 1,2 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 步骤 5 中的图像 2,2
    • Remove the two screws from the top side of the device.
    • Remove the two screws from the bottom side of the device.
  6. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 步骤 6 中的图像 1,1
    • Remove the rear cover.
    • Be careful not to lose the spring inside.
  7. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 步骤 7 中的图像 1,1
    • Pull back the front cover so that you can dislodge the side cover.
  8. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 步骤 8 中的图像 1,1
    • Unfold the device and be careful not to tear the black and red power supply wires.
  9. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 步骤 9 中的图像 1,1
    • Remove the four screws from the motherboard.
  10. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 步骤 10 中的图像 1,1
    • Take out the motherboard while disconnecting the flip screen's cable from underneath.
  11. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 步骤 11 中的图像 1,1
    • Replace the Lens Assembly board.
    • Be careful not to damage any of the pins. Pull the board linearly.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 6-4, Brown Winter 2015 USF Tampa, Team 6-4, Brown Winter 2015 的会员
USFT-BROWN-W15S6G4
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 199
