跳转到主内容
加入维修社区 - 创建账户
Aiptek DZO-V58N Image Sensor Replacement
你所需要的
  1. Aiptek DZO-V58N Image Sensor Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery compartment on the back of the camera. It is the panel with the plastic ridges for simple removal.
    • Slide the battery compartment cover down off of the camera body.
    询问修复机器人
  2. Aiptek DZO-V58N Image Sensor Replacement: 步骤 2 中的图像 1,1
    • Pry up the battery from the bottom using a finger and remove the batter from the case.
    询问修复机器人
  3. Aiptek DZO-V58N Image Sensor Replacement, Lens Protector: 步骤 3 中的图像 1,1
    • Remove the lanyard by pulling the grey lace through the black string loop.
    • Pull black string loop through the silver bracket.
    询问修复机器人
  4. Aiptek DZO-V58N Image Sensor Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to pry off the black control cover.
    • The face plates are glued, so use force to pry the face plates from the camera body.
    询问修复机器人
  5. Aiptek DZO-V58N Image Sensor Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to pry off the ridged back face plate and the black button.
    • The button is loose and should come off with little or no effort.
    询问修复机器人
  6. Aiptek DZO-V58N Image Sensor Replacement: 步骤 6 中的图像 1,1
    • Use a plastic opening tool to pry off the silver face plate.
    询问修复机器人
  7. Aiptek DZO-V58N Image Sensor Replacement: 步骤 7 中的图像 1,3 Aiptek DZO-V58N Image Sensor Replacement: 步骤 7 中的图像 2,3 Aiptek DZO-V58N Image Sensor Replacement: 步骤 7 中的图像 3,3
    • Open the USB cover to expose the small machine screw.
    • Use the Phillips #00 screwdriver to unscrew the six 0.5cm machine case screws (distributed around the camera body).
    • These small screws are easy to lose. Place the removed screws in an organized container to avoid losing them.
    询问修复机器人
  8. Aiptek DZO-V58N Image Sensor Replacement: 步骤 8 中的图像 1,1
    • Pull off the side control panel.
    询问修复机器人
  9. Aiptek DZO-V58N Image Sensor Replacement: 步骤 9 中的图像 1,2 Aiptek DZO-V58N Image Sensor Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Flip open the screen by pulling the loose end of the screen away from the case.
    • Use tweezers to remove the two outside rubber dots to reveal the two 0.5cm machine screws.
    • Use the #00 Phillips Screwdriver to remove both screws.
    询问修复机器人
  10. Aiptek DZO-V58N Image Sensor Replacement: 步骤 10 中的图像 1,2 Aiptek DZO-V58N Image Sensor Replacement: 步骤 10 中的图像 2,2
    • Pull the body apart from the bottom of device just enough to make space to remove the silver plastic strap holder.
    • Use tweezers to remove the silver plastic strap holder.
    • Use a plastic opening tool to pry off the lens protector.
    询问修复机器人
  11. Aiptek DZO-V58N Image Sensor Replacement, Lens: 步骤 11 中的图像 1,3 Aiptek DZO-V58N Image Sensor Replacement, Lens: 步骤 11 中的图像 2,3 Aiptek DZO-V58N Image Sensor Replacement, Lens: 步骤 11 中的图像 3,3
    • Unscrew the two silver 0.5cm machine screws with the #00 Phillips screwdriver.
    • Lift off the lens protector housing.
    • Pull apart the two halves of the camera body.
    • Do not pull the two halves apart too far because the wires may detach.
    询问修复机器人
  12. Aiptek DZO-V58N Image Sensor Replacement: 步骤 12 中的图像 1,1
    • Unscrew both black machine screws holding the lens in place with the #00 Phillips screwdriver.
    询问修复机器人
  13. Aiptek DZO-V58N Image Sensor Replacement: 步骤 13 中的图像 1,1
    • Carefully remove the compressed springs underneath each of the two screws that were removed in the previous step.
    • Be careful not to lose the springs. The springs are in compression and will launch from the camera if not held onto.
    询问修复机器人
  14. Aiptek DZO-V58N Image Sensor Replacement: 步骤 14 中的图像 1,1
    • Lift off the lens.
    询问修复机器人
  15. Aiptek DZO-V58N Image Sensor Replacement, Image Sensor: 步骤 15 中的图像 1,2 Aiptek DZO-V58N Image Sensor Replacement, Image Sensor: 步骤 15 中的图像 2,2
    • Use the #00 Phillips Screwdriver to unscrew the 3 circuit board screws.
    • Slightly separate circuit board from plastic case by lifting the circuit board straight out.
    询问修复机器人
  16. Aiptek DZO-V58N Image Sensor Replacement: 步骤 16 中的图像 1,2 Aiptek DZO-V58N Image Sensor Replacement: 步骤 16 中的图像 2,2
    • Unplug the image sensor from the circuit board.
    • Pull the image sensor straight out to avoid damage to the pin connectors.
    询问修复机器人
结论
Zachary Yun
于04/03/12注册
28 声望
创作了5篇指南
团队
Cal Poly, Team 5-5, Forte Spring 2012 Cal Poly, Team 5-5, Forte Spring 2012 的会员
CPSU-FORTE-S12S5G5
5 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 47
总计 1,068
