跳转到主内容
加入维修社区 - 创建账户
Afterglow Wireless PS3 Controller Button Replacement
你所需要的
    1. Afterglow Wireless PS3 Controller Button Replacement, Back Cover: 步骤 1 中的图像 1,2 Afterglow Wireless PS3 Controller Button Replacement, Back Cover: 步骤 1 中的图像 2,2
      • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
      • Lift up and remove the controller back plate.
      添加评论
    1. Afterglow Wireless PS3 Controller Button Replacement, Button: 步骤 2 中的图像 1,2 Afterglow Wireless PS3 Controller Button Replacement, Button: 步骤 2 中的图像 2,2
      • Carefully remove the battery by lifting it straight up from its place.
      • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
      询问修复机器人
      添加评论
    2. Afterglow Wireless PS3 Controller Button Replacement: 步骤 3 中的图像 1,1
      • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
      询问修复机器人
      添加评论
    3. Afterglow Wireless PS3 Controller Button Replacement: 步骤 4 中的图像 1,2 Afterglow Wireless PS3 Controller Button Replacement: 步骤 4 中的图像 2,2
      • Jiggle both joy stick control mini-motherboards out of their holding place.
      • Set aside the mini-motherboards so you can access the main motherboard.
      询问修复机器人
      添加评论
    4. Afterglow Wireless PS3 Controller Button Replacement: 步骤 5 中的图像 1,2 Afterglow Wireless PS3 Controller Button Replacement: 步骤 5 中的图像 2,2
      • Pull both vibration motors straight up from their holding place.
      询问修复机器人
      添加评论
    5. Afterglow Wireless PS3 Controller Button Replacement: 步骤 6 中的图像 1,2 Afterglow Wireless PS3 Controller Button Replacement: 步骤 6 中的图像 2,2
      • Unscrew the two 9mm Phillips #0 screws holding the motherboard to the controller front plate.
      询问修复机器人
      添加评论
    6. Afterglow Wireless PS3 Controller Button Replacement: 步骤 7 中的图像 1,2 Afterglow Wireless PS3 Controller Button Replacement: 步骤 7 中的图像 2,2
      • Detach the main motherboard fom the front pate by carefully pulling it off.
      • Be careful of the trigger buttons when pulling out the motherboard. The buttons have mini-motherboards secured in place on the front plate. Carefully pull these out.
      询问修复机器人
      添加评论
    7. Afterglow Wireless PS3 Controller Button Replacement: 步骤 8 中的图像 1,3 Afterglow Wireless PS3 Controller Button Replacement: 步骤 8 中的图像 2,3 Afterglow Wireless PS3 Controller Button Replacement: 步骤 8 中的图像 3,3
      • Pick up the controller front plate and carefully turn it over so that the buttons left in it will fall out.
      • You may want to flip it while holding it over a container so the buttons do not go bouncing away from your work space.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
Aj Coello
于02/17/17注册
1,164 声望
创作了6篇指南
团队
USF Tampa, Team S19-G5, Hoffman Spring 2017 USF Tampa, Team S19-G5, Hoffman Spring 2017 的会员
USFT-HOFFMAN-S17S19G5
4 名成员
创作了96篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 76
总计 2,739
