跳转到主内容
Afridev Tank Replacement
你所需要的
  1. Afridev Tank Replacement, Head: 步骤 1 中的图像 1,2 Afridev Tank Replacement, Head: 步骤 1 中的图像 2,2
    • Assemble the required tools, including the Afridev tool and crescent wrenches.
  2. Afridev Tank Replacement: 步骤 2 中的图像 1,3 Afridev Tank Replacement: 步骤 2 中的图像 2,3 Afridev Tank Replacement: 步骤 2 中的图像 3,3
    • Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
  3. Afridev Tank Replacement: 步骤 3 中的图像 1,2 Afridev Tank Replacement: 步骤 3 中的图像 2,2
    • Loosen the bolt on front of the face plate with the Afridev tool.
    • Remove the plate from the pump by lifting it straight up.
  4. Afridev Tank Replacement, Axle and Handle: 步骤 4 中的图像 1,3 Afridev Tank Replacement, Axle and Handle: 步骤 4 中的图像 2,3 Afridev Tank Replacement, Axle and Handle: 步骤 4 中的图像 3,3
    • Insert the T-handle into the top cylinder of the exposed pump rod.
  5. Afridev Tank Replacement: 步骤 5 中的图像 1,2 Afridev Tank Replacement: 步骤 5 中的图像 2,2
    • Loosen the 2 bolts on either side of handle.
    • It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle.
  6. Afridev Tank Replacement: 步骤 6 中的图像 1,3 Afridev Tank Replacement: 步骤 6 中的图像 2,3 Afridev Tank Replacement: 步骤 6 中的图像 3,3
    • Loosen the 2 bolts on either side of the head to remove the handle from the pump rod.
  7. Afridev Tank Replacement: 步骤 7 中的图像 1,2 Afridev Tank Replacement: 步骤 7 中的图像 2,2
    • Lift the handle to a horizontal position.
  8. Afridev Tank Replacement: 步骤 8 中的图像 1,3 Afridev Tank Replacement: 步骤 8 中的图像 2,3 Afridev Tank Replacement: 步骤 8 中的图像 3,3
    • While one person lifts up on the T-handle, remove the bolt and connection pieces.
  9. Afridev Tank Replacement: 步骤 9 中的图像 1,3 Afridev Tank Replacement: 步骤 9 中的图像 2,3 Afridev Tank Replacement: 步骤 9 中的图像 3,3
    • Remove the bolt and connection pieces from the handle.
    • Set the bolt pieces in a sanitary place, such as a bucket, to prevent contamination.
  10. Afridev Tank Replacement: 步骤 10 中的图像 1,2 Afridev Tank Replacement: 步骤 10 中的图像 2,2
    • Remove the handle from the pump.
    • Be sure to set the handle in a sanitary place to prevent contamination.
  11. Afridev Tank Replacement, Pump Rod: 步骤 11 中的图像 1,2 Afridev Tank Replacement, Pump Rod: 步骤 11 中的图像 2,2
    • Grab firmly on the T-handle and lift the pump rod straight up.
    • Expose the first connection of the pump rod, and support the portion below the connection.
  12. Afridev Tank Replacement: 步骤 12 中的图像 1,2 Afridev Tank Replacement: 步骤 12 中的图像 2,2
    • While holding the pump rod below the first connection tightly, lower the first portion of the rod to a horizontal position.
  13. Afridev Tank Replacement: 步骤 13 中的图像 1,3 Afridev Tank Replacement: 步骤 13 中的图像 2,3 Afridev Tank Replacement: 步骤 13 中的图像 3,3
    • Unhook the first connection by pushing it out and down, then pulling it away from the rest of the rod.
  14. Afridev Tank Replacement: 步骤 14 中的图像 1,3 Afridev Tank Replacement: 步骤 14 中的图像 2,3 Afridev Tank Replacement: 步骤 14 中的图像 3,3
    • Repeat steps 11-13 for the remaining sections of pump rod.
    • Be sure to set the pump rod segments above the ground to avoid contamination.
  15. Afridev Tank Replacement, Tank: 步骤 15 中的图像 1,2 Afridev Tank Replacement, Tank: 步骤 15 中的图像 2,2
    • Place one wrench on the top side of the top base of the tank spout.
    • Place another wrench on the underside of the bolt in order to get more leverage.
    • Pull the top wrench to the right, and the bottom wrench to the left.
  16. Afridev Tank Replacement: 步骤 16 中的图像 1,3 Afridev Tank Replacement: 步骤 16 中的图像 2,3 Afridev Tank Replacement: 步骤 16 中的图像 3,3
    • Remove the loosened bolt from the pump.
    • Repeat this procedure for the 3 remaining bolts.
  17. Afridev Tank Replacement: 步骤 17 中的图像 1,2 Afridev Tank Replacement: 步骤 17 中的图像 2,2
    • Lift the tank straight up to remove it from the pump.
    • Be sure to place the tank in a sanitary place to prevent contamination.
结论
另外一个人完成了本指南。
Jake Devincenzi
于04/18/11注册
117,269 声望
创作了57篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 305
