当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Loosen the 2 bolts on either side of handle.
It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle.
Loosen the 2 bolts on either side of the head to remove the handle from the pump rod.
Remove the bolt and connection pieces from the handle.
Set the bolt pieces in a sanitary place, such as a bucket, to prevent contamination.
Grab firmly on the T-handle and lift the pump rod straight up.
Expose the first connection of the pump rod, and support the portion below the connection.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
