跳转到主内容
Aerogarden Air Pump Replacement
视频概述
  1. Aerogarden Air Pump Replacement, Aerogarden Air Pump: 步骤 1 中的图像 1,2 Aerogarden Air Pump Replacement, Aerogarden Air Pump: 步骤 1 中的图像 2,2
    • Remove the water and seed pod container and set it aside.
  2. Aerogarden Air Pump Replacement: 步骤 2 中的图像 1,2 Aerogarden Air Pump Replacement: 步骤 2 中的图像 2,2
    • Peel back the footpads at the bottom.
    • Unscrew the eight screws on the bottom to remove the base
  3. Aerogarden Air Pump Replacement: 步骤 3 中的图像 1,2 Aerogarden Air Pump Replacement: 步骤 3 中的图像 2,2
    • Disconnect the wires for the lights so the base can be fully opened.
  4. Aerogarden Air Pump Replacement: 步骤 4 中的图像 1,2 Aerogarden Air Pump Replacement: 步骤 4 中的图像 2,2
    • Remove the four screws holding the pump down
  5. Aerogarden Air Pump Replacement: 步骤 5 中的图像 1,2 Aerogarden Air Pump Replacement: 步骤 5 中的图像 2,2
    • Cut the wires as close to the pump as possible, to preserve their length. The wire connections are covered with glue
    • Strip the plastic from about 1/8 inch of the wire ends.
    • On the circuit board, note which wire is positive, and which wire is negative.
  6. Aerogarden Air Pump Replacement: 步骤 6 中的图像 1,2 Aerogarden Air Pump Replacement: 步骤 6 中的图像 2,2
    • Connect the wires to the new pump and solder them in or affix them with heat shrink tubing for wires. Well, the solder should be covered with the heat shrink tubing, as well, since it is a potentially wet environment.
  7. Aerogarden Air Pump Replacement: 步骤 7 中的图像 1,3 Aerogarden Air Pump Replacement: 步骤 7 中的图像 2,3 Aerogarden Air Pump Replacement: 步骤 7 中的图像 3,3
    • Assemble in reverse order.
结论
Jameslimon
于03/20/24注册
145 声望
撰写一个指南
团队
CSU Los Angeles, Team 1-59, Harris Spring 2024 CSU Los Angeles, Team 1-59, Harris Spring 2024 的会员
CSULA-HARRIS-S24S1G59
2 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 19
总计 46
