跳转到主内容
AeraMax Pro AM III Air Filter Replacement
精选文档
  1. AeraMax Pro AM III Air Filter Replacement, Air Filter: 步骤 1 中的图像 1,3 AeraMax Pro AM III Air Filter Replacement, Air Filter: 步骤 1 中的图像 2,3 AeraMax Pro AM III Air Filter Replacement, Air Filter: 步骤 1 中的图像 3,3
    • If the access panel is locked, use the key to unlock it and open it by pressing the levers on both sides.
    • The appliance can open only if both levers are pressed simultaneously.
    • Use your hands to remove the old filter.
  2. AeraMax Pro AM III Air Filter Replacement: 步骤 2 中的图像 1,3 AeraMax Pro AM III Air Filter Replacement: 步骤 2 中的图像 2,3 AeraMax Pro AM III Air Filter Replacement: 步骤 2 中的图像 3,3
    • When removing the old filter, do not throw away the filter cage. Wipe it down and prepare to use it for the new filter.
    • If you have not already wiped down your appliance, give it a thorough wipe-down with your preferred cleaning product.
  3. AeraMax Pro AM III Air Filter Replacement: 步骤 3 中的图像 1,3 AeraMax Pro AM III Air Filter Replacement: 步骤 3 中的图像 2,3 AeraMax Pro AM III Air Filter Replacement: 步骤 3 中的图像 3,3
    • Remove the plastic from the new HEPA filter and place it into the filter cage.
  4. AeraMax Pro AM III Air Filter Replacement: 步骤 4 中的图像 1,3 AeraMax Pro AM III Air Filter Replacement: 步骤 4 中的图像 2,3 AeraMax Pro AM III Air Filter Replacement: 步骤 4 中的图像 3,3
    • Insert the carbon filter into the filter cage that you wiped down and make sure the corners are aligned with the filter cage.
    • Take your new HEPA filter and make sure the stickers are aligned and the corners of the pre-filter are fleshed down until it sticks to the carbon filter.
  5. AeraMax Pro AM III Air Filter Replacement: 步骤 5 中的图像 1,3 AeraMax Pro AM III Air Filter Replacement: 步骤 5 中的图像 2,3 AeraMax Pro AM III Air Filter Replacement: 步骤 5 中的图像 3,3
    • Insert your filter cage back into the access panel and make sure that the filter label is visible and facing upwards.
    • You can give your appliance one more wipe-down to ensure cleanliness.
  6. AeraMax Pro AM III Air Filter Replacement: 步骤 6 中的图像 1,3 AeraMax Pro AM III Air Filter Replacement: 步骤 6 中的图像 2,3 AeraMax Pro AM III Air Filter Replacement: 步骤 6 中的图像 3,3
    • Press the HEPA Setting for three seconds until the icon turns green.
    • The green icon indicates that the filter has been replaced and is ready to be used.
    • Close the access panel.
终点
另外一个人完成了本指南。
附加文件
Pita Vaouli
于08/22/22注册
157 声望
撰写一个指南
团队
CSU Los Angeles, Team P-2, Briggs Fall 2022 CSU Los Angeles, Team P-2, Briggs Fall 2022 的会员
CSULA-BRIGGS-F22SPG2
1 名成员
创作了1篇指南
一条评论
I have a brand new Air purifier just like the one in your demonstration I would like to sell, it's still in the box. I don't know how much to ask for it or where I can sell it. Can you help me?
Danette Dinot - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 211
