跳转到主内容
Adjusting the alarm glass breakage microphone sensitivity
你所需要的
  1. Adjusting the alarm glass breakage microphone sensitivity: 步骤 2 中的图像 1,1
    • Once the glove box is out of the way, it's easy to spot the alarm unit. The green connector will be plugged into it. I had already unplugged it when I took this picture.
  2. Adjusting the alarm glass breakage microphone sensitivity: 步骤 3 中的图像 1,1
    • It may be stubborn to get out because it is stuck down with double stick foam pads.
  3. Adjusting the alarm glass breakage microphone sensitivity: 步骤 4 中的图像 1,1
    • Remove the 4 screws (may be under the foam strips). This is the bottom of the circuit board.
  4. Adjusting the alarm glass breakage microphone sensitivity: 步骤 5 中的图像 1,1
    • Turn the board over and locate the 2 position dip switch.
    • This dip switch adjusts the glass breakage microphone sensitivity
    • Sensitivity settings:
    • 1 off & 2 off = high
    • 1 on & 2 off = mid (factory setting)
    • 1 off & 2 on = low
    • 1 on & 2 on = super low
结论
3等其他人完成本指南。
mpeeples
于04/04/10注册
184 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 2,481
