跳转到主内容
Adjusting Nishiki Aero II Seat
你所需要的
  1. Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: 步骤 1 中的图像 1,3 Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: 步骤 1 中的图像 2,3 Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: 步骤 1 中的图像 3,3
    • Loosen the bolt that secures your seat.
    • To do so, use one wrench to hold the larger nut on the left side of the bike still while you loosen the nut on the right.
  2. Adjusting Nishiki Aero II Seat: 步骤 2 中的图像 1,2 Adjusting Nishiki Aero II Seat: 步骤 2 中的图像 2,2
    • Now that it can move, move the seat by wiggling it and pulling it in the direction you want to adjust it.
    • You want to the adjust the seat so that, when a pedal is at the far end of its rotation, your leg is fully extended.
    • Don't worry about getting it perfect on the first try. Instead, guess your adjustment, tighten the bolt a little bit, try it out, and adjust again until you get it right.
  3. Adjusting Nishiki Aero II Seat: 步骤 3 中的图像 1,1
    • Once your seat is at the desired height, you just tighten the bolt the same way you loosened it.
    • Use two wrenches, one to hold it still and the other to tighten the nut.
    • Make sure it's very tight, or else the seat might twist or lower over time.
结论
Tobias Elder
于04/25/13注册
113 声望
创作了7篇指南
团队
Cal Poly, Team 21-53, Johann Spring 2013 Cal Poly, Team 21-53, Johann Spring 2013 的会员
CPSU-JOHANN-S13S21G53
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 34
总计 2,803
