简介
If your calculator does not appear to light up, it could be that the contrast is at a low setting. Use this guide to aid you in adjusting the contrast.
  1. Remove the front protective cover by sliding it off of the calculator. Press the "ON" button to turn on the calculator.
    • Remove the front protective cover by sliding it off of the calculator.
    • Press the "ON" button to turn on the calculator.
  2. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Press the "2ND" button at the top left portion of the keypad. An arrow pointing up will appear at the top left corner of the screen. Press and hold the "UP" arrow until you have increased the contrast to a level that is easily visible for yourself. A common level to set the contrast is 5. To decrease the contrast, press the "2ND" button, then press and hold the "DOWN" arrow.
    • Press the "2ND" button at the top left portion of the keypad. An arrow pointing up will appear at the top left corner of the screen.
    • Press and hold the "UP" arrow until you have increased the contrast to a level that is easily visible for yourself. A common level to set the contrast is 5.
    • To decrease the contrast, press the "2ND" button, then press and hold the "DOWN" arrow.
结论
Now you should have the image contrast set to your preferences.
另外一个人完成了本指南。
Alan Wong
于2012年09月26日注册
63 信誉积分
创作了2篇指南
团队
Cal Poly, Team 7-52, Forte Fall 2012 Cal Poly, Team 7-52, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G52
5 名成员
创作了11篇指南
浏览统计数据:
过去的24小时: 1
过去的7天: 7
过去的30天: 62
总计 4,039
