简介
This guide will show you how to adjust the height of the handle bars and align the stem with the front wheel.
配件
无需配件。
  1. Remove the bolt cover with a flathead screwdriver. Remove the bolt cover with a flathead screwdriver.
    • Remove the bolt cover with a flathead screwdriver.
  2. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench. After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side. If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  4. Align the direction of the goose-neck (adjustable quill stem) with the front tire. Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench. Pop the bolt cover back on.
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
终点
另外一个人完成了本指南。
aaron thielk
于2010年10月10日注册
1,726 信誉积分
创作了5篇指南
团队
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G13
4 名成员
创作了11篇指南
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - 回复
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 14
总计 7,874
