跳转到主内容
AcuRite 02032 Wind Vane Replacement
你所需要的
  1. AcuRite 02032 Wind Vane Replacement, Battery: 步骤 1 中的图像 1,3 AcuRite 02032 Wind Vane Replacement, Battery: 步骤 1 中的图像 2,3 AcuRite 02032 Wind Vane Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the battery compartment lid by lifting upward.
  2. AcuRite 02032 Wind Vane Replacement: 步骤 2 中的图像 1,1
    • Pull the ribbon to eject the 2 X AA alkaline batteries.
  3. AcuRite 02032 Wind Vane Replacement: 步骤 3 中的图像 1,3 AcuRite 02032 Wind Vane Replacement: 步骤 3 中的图像 2,3 AcuRite 02032 Wind Vane Replacement: 步骤 3 中的图像 3,3
    • Once the batteries are removed, it is safe to proceed.
  4. AcuRite 02032 Wind Vane Replacement, Wind Vane: 步骤 4 中的图像 1,3 AcuRite 02032 Wind Vane Replacement, Wind Vane: 步骤 4 中的图像 2,3 AcuRite 02032 Wind Vane Replacement, Wind Vane: 步骤 4 中的图像 3,3
    • Firmly grasp the windvane with one hand and the rest of the device with the other hand.
    • Pull straight outwards. A quick yank with force should be enough to remove the propeller.
  5. AcuRite 02032 Wind Vane Replacement: 步骤 5 中的图像 1,2 AcuRite 02032 Wind Vane Replacement: 步骤 5 中的图像 2,2
    • To reattach the replacement wind vane, line up the small notch in the socket where the pieces fit together then carefully push the parts together.
结论
另外一个人完成了本指南。
Ben Kegel
于09/15/16注册
350 声望
创作了3篇指南
团队
CSU Fullerton, Team 1-4, Bruce Fall 2016 CSU Fullerton, Team 1-4, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S1G4
5 名成员
创作了7篇指南
一条评论
I had a herd of elk come through my yard (judging by the large hoofprints). Apparently one of them got tangled up in the guy rope for my antenna mast and the mast came tumbling to the ground. At the top of the mast about 35 feet up was my Acurite 5-in-1 Sensor, which also fell to the ground and broke the wind vane. The replacement vane cost 5 dollars. Pull off the broken one, push on the new one, done in a few seconds.
Acurite’s instructions about replacing the wind vane are as follows:
“The wind vane is pressed onto the shaft, pull firmly to remove it. To attach the wind vane, align the wind vane with the flat on the shaft and press into place.”
They don’t say anything about removing the batteries.
Hal Jordan - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 24
总计 1,266
