跳转到主内容
AcuRite 02032 Wind Cup Assembly Replacement
你所需要的
  1. AcuRite 02032 Wind Cup Assembly Replacement, Battery: 步骤 1 中的图像 1,3 AcuRite 02032 Wind Cup Assembly Replacement, Battery: 步骤 1 中的图像 2,3 AcuRite 02032 Wind Cup Assembly Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the battery compartment lid by lifting upward.
  2. AcuRite 02032 Wind Cup Assembly Replacement: 步骤 2 中的图像 1,1
    • Pull the ribbon to eject the 2 X AA alkaline batteries.
  3. AcuRite 02032 Wind Cup Assembly Replacement: 步骤 3 中的图像 1,3 AcuRite 02032 Wind Cup Assembly Replacement: 步骤 3 中的图像 2,3 AcuRite 02032 Wind Cup Assembly Replacement: 步骤 3 中的图像 3,3
    • Once the batteries are removed, it is safe to proceed.
  4. AcuRite 02032 Wind Cup Assembly Replacement, Base: 步骤 4 中的图像 1,1
    • Remove the four 0.8cm screws that attach the bottom panel to the device
    • An extended driver is needed to reach 3 of these screws. If you are using the 64 - bit driver kit you can extend the driver by inserting the driver PH1, (Phillips size 1) into the size 4 hexagonal adapter.
  5. AcuRite 02032 Wind Cup Assembly Replacement: 步骤 5 中的图像 1,2 AcuRite 02032 Wind Cup Assembly Replacement: 步骤 5 中的图像 2,2
    • Gently lift the top section of the weather center away from the base. With all the screws removed it should lift off easily.
  6. AcuRite 02032 Wind Cup Assembly Replacement, Wind Cup Assembly: 步骤 6 中的图像 1,1
    • Remove the four 0.8cm screws inside the case located near the fan using the J1 screw bit.
  7. AcuRite 02032 Wind Cup Assembly Replacement: 步骤 7 中的图像 1,2 AcuRite 02032 Wind Cup Assembly Replacement: 步骤 7 中的图像 2,2
    • With all four screws removed, the wind cup assembly should lift straight up off the middle section.
    • Set down the bottom half of the weather center careful. There are two small pegs that will break with the slightest amount of pressure.
  8. AcuRite 02032 Wind Cup Assembly Replacement: 步骤 8 中的图像 1,1
    • Replace the old wind cup assembly with the new assembly that was purchased.
结论
Ben Kegel
于09/15/16注册
350 声望
创作了3篇指南
团队
CSU Fullerton, Team 1-4, Bruce Fall 2016 CSU Fullerton, Team 1-4, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S1G4
5 名成员
创作了7篇指南
3条评论
Do you have to replace the whole top, wind cups,top plate with solar panel, just for the wind cups?
Tom Halverson - 回复
For a broken wind cups do you have to replace the top section with the solar panel?
Tom Halverson - 回复
No. After you take it apart hold the shaft turn broken cup assy off. Install new cups in reverse order.
Larry Lindsay - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,576
