你所需要的
Remove the four 0.8cm screws inside the case located near the fan using the J1 screw bit.
即将完成!
结论
3条评论
Do you have to replace the whole top, wind cups,top plate with solar panel, just for the wind cups?
For a broken wind cups do you have to replace the top section with the solar panel?
No. After you take it apart hold the shaft turn broken cup assy off. Install new cups in reverse order.
