跳转到主内容
加入维修社区 - 创建账户
Acoustic Bass Preamp Replacement
你所需要的
  1. Acoustic Bass Preamp Replacement, Preamp: 步骤 1 中的图像 1,2 Acoustic Bass Preamp Replacement, Preamp: 步骤 1 中的图像 2,2
    • Use a guitar string winder to carefully remove each string.
  2. Acoustic Bass Preamp Replacement: 步骤 2 中的图像 1,3 Acoustic Bass Preamp Replacement: 步骤 2 中的图像 2,3 Acoustic Bass Preamp Replacement: 步骤 2 中的图像 3,3
    • Look inside the bass for the preamp tuning box.
    • Once you find it, unplug the small jack.
  3. Acoustic Bass Preamp Replacement: 步骤 3 中的图像 1,2 Acoustic Bass Preamp Replacement: 步骤 3 中的图像 2,2
    • Cut the zip tie holding the excess length of wires in place. This is located inside the bass.
    • The zip tie is most likely right under the bridge of the bass.
    • This will allow you to disassemble all parts the wires will connect to later on in the repair.
  4. Acoustic Bass Preamp Replacement: 步骤 4 中的图像 1,2 Acoustic Bass Preamp Replacement: 步骤 4 中的图像 2,2
    • Pull out the pick-up stick from the bridge of the base.
  5. Acoustic Bass Preamp Replacement: 步骤 5 中的图像 1,2 Acoustic Bass Preamp Replacement: 步骤 5 中的图像 2,2
    • Look for the tuner/equalizer/preamp and carefully remove each screw using a Phillips screwdriver.
    • Once screws are removed, look for the endpin jack and remove it.
    • In the first image, the part had already fallen off. Refer to the second image if you have trouble finding the endpin jack.
  6. Acoustic Bass Preamp Replacement: 步骤 6 中的图像 1,3 Acoustic Bass Preamp Replacement: 步骤 6 中的图像 2,3 Acoustic Bass Preamp Replacement: 步骤 6 中的图像 3,3
    • Place the tuner over the area you removed the previous one from.
    • Scratch a line around the opening to the area of the bottom portion of the tuner.
    • Refer to the second image for a visual reference.
    • Ensure the scratched guideline is made to the parameter of the parts behind the face of the tuner.
  7. Acoustic Bass Preamp Replacement: 步骤 7 中的图像 1,3 Acoustic Bass Preamp Replacement: 步骤 7 中的图像 2,3 Acoustic Bass Preamp Replacement: 步骤 7 中的图像 3,3
    • Using a metal file, file up and down, following the outline.
    • Continue this, going around the outline until the desired opening is made.
    • This will most likely take quite a bit of time. If you have access to a small jab saw or similar power tool it will speed up the process.
    • Do this step ideally in a well-ventilated area as the wood shaving are small, and inhalation can cause harm or injury. Wear protective gear like a face mask, and goggles/eye protection to prevent injury or pain.
  8. Acoustic Bass Preamp Replacement: 步骤 8 中的图像 1,3 Acoustic Bass Preamp Replacement: 步骤 8 中的图像 2,3 Acoustic Bass Preamp Replacement: 步骤 8 中的图像 3,3
    • Get your output platform and measure, with a ruler, the perimeter of the parts under the face with the screw holes.
    • The second and third images show the underside of the part, measuring around the internals.
    • Once you measure each side, jot them down for Step 9.
  9. Acoustic Bass Preamp Replacement: 步骤 9 中的图像 1,3 Acoustic Bass Preamp Replacement: 步骤 9 中的图像 2,3 Acoustic Bass Preamp Replacement: 步骤 9 中的图像 3,3
    • Use a pencil and paper to outline the measurements jotted down.
    • Cut the shape out using a pair of scissors.
    • Place the paper over the opening on the guitar and trace the perimeter of the paper.
  10. Acoustic Bass Preamp Replacement: 步骤 10 中的图像 1,3 Acoustic Bass Preamp Replacement: 步骤 10 中的图像 2,3 Acoustic Bass Preamp Replacement: 步骤 10 中的图像 3,3
    • Insert the file into the opening and file up until you reach the outline you traced.
    • Then follow the outline until the opening is completely cut out.
    • Do this step ideally in a well-ventilated area as the wood shaving are small, and you may inhale them.
  11. Acoustic Bass Preamp Replacement: 步骤 11 中的图像 1,3 Acoustic Bass Preamp Replacement: 步骤 11 中的图像 2,3 Acoustic Bass Preamp Replacement: 步骤 11 中的图像 3,3
    • Place the preamp into the opening and screw into place with your power drill.
    • A power drill and four screws are required in this step. This will allow you to create a hole to screw in the screws or just directly screw in the screw without drilling holes.
  12. Acoustic Bass Preamp Replacement: 步骤 12 中的图像 1,2 Acoustic Bass Preamp Replacement: 步骤 12 中的图像 2,2
    • Using your power drill and the other four screws, drill the screws into the output platform openings.
  13. Acoustic Bass Preamp Replacement: 步骤 13 中的图像 1,3 Acoustic Bass Preamp Replacement: 步骤 13 中的图像 2,3 Acoustic Bass Preamp Replacement: 步骤 13 中的图像 3,3
    • Get your pickup stick and insert it into the hole in the bridge.
    • Look into the guitar for the end of the pick-up stick and pull it until it reaches the preamp box.
    • Plug in the pickup stick jack into the box, as seen in the fourth image.
  14. Acoustic Bass Preamp Replacement: 步骤 14 中的图像 1,2 Acoustic Bass Preamp Replacement: 步骤 14 中的图像 2,2
    • Look for the preamp inside the bass. You will find a wire showed in the first image.
    • Stretch your arm into the bass to reach the output platform and find where you will need to plug the wire into.
    • Ensure the wire plugs in the right way and is firmly plugged in.
  15. Acoustic Bass Preamp Replacement: 步骤 15 中的图像 1,2 Acoustic Bass Preamp Replacement: 步骤 15 中的图像 2,2
    • Use a zip tie to secure the extra length of wire inside the bass.
    • This step is not required but will help disguise wires and keep them tucked inside the bass.
  16. Acoustic Bass Preamp Replacement: 步骤 16 中的图像 1,2 Acoustic Bass Preamp Replacement: 步骤 16 中的图像 2,2
    • Replace the old strings or install new strings to the bass.
    • Use the string winder to make this step a lot faster.
结论
Congratulations! You have just retrofitted a new amp into your bass.
Had trouble with one of the steps? Leave a comment letting us know how we can help!
Juan Chavez
于04/03/23注册
304 声望
撰写一个指南
团队
CSU Los Angeles, Team 77-86, Briggs Spring 2023 CSU Los Angeles, Team 77-86, Briggs Spring 2023 的会员
CSULA-BRIGGS-S23S77G86
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 49
总计 1,261
