跳转到主内容
修复你的物品
维修的权力
商店
简介
How to replace optical drive for Acer Travelmate 220 due to malfunctioning disk drive. Symptoms are drive does not read disks, does not respond to inserted disks, or if there are multiple disk drive errors.
配件
没有特定配件。
  1. Flip your computer over so the bottom case is facing you.
    • Flip your computer over so the bottom case is facing you.
  2. Locate the sliding unlock button near the AC power input.
    • Locate the sliding unlock button near the AC power input.
  3. Slide the button in the direction of unlock and hold.
    • Slide the button in the direction of unlock and hold.
  4. Gently pull the disk drive out.
    • Gently pull the disk drive out.
  5. Remove the four screws from the sides of the black plastic using a Phillips #00 screwdriver. Remove the four screws from the sides of the black plastic using a Phillips #00 screwdriver. Remove the four screws from the sides of the black plastic using a Phillips #00 screwdriver.
    • Remove the four screws from the sides of the black plastic using a Phillips #00 screwdriver.
  6. Remove the black plastic that covers the metal. Remove the black plastic that covers the metal.
    • Remove the black plastic that covers the metal.
  7. Locate the green chip on the back of the drive.
    • Locate the green chip on the back of the drive.
  8. Remove the two screws securing the green chip. Remove the two screws securing the green chip.
    • Remove the two screws securing the green chip.
  9. Firmly pull off the green chip.
    • Firmly pull off the green chip.
  10. Insert the green chip in the new disk drive.
    • Insert the green chip in the new disk drive.
结论
另外一个人完成了本指南。
Justin
于2011年10月04日注册
62 信誉积分
撰写一个指南
团队
UW Stout, Team 5-5, Zhou Fall 2011 UW Stout, Team 5-5, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S5G5
3 名成员
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 4
总计 4,338
