跳转到主内容
Acer TravelMate P653-V-6882 RAM Replacement
你所需要的
  1. Acer TravelMate P653-V-6882 RAM Replacement, Battery Pack: 步骤 1 中的图像 1,2 Acer TravelMate P653-V-6882 RAM Replacement, Battery Pack: 步骤 1 中的图像 2,2
    • Turn the computer over so the base is facing up.
    • Slide the battery lock to unlock position.
  2. Acer TravelMate P653-V-6882 RAM Replacement: 步骤 2 中的图像 1,1
    • Slide the battery release latch to the right.
    • The battery pack will pop out.
  3. Acer TravelMate P653-V-6882 RAM Replacement: 步骤 3 中的图像 1,1
    • Lift the battery up.
    • Pull out the battery.
  4. Acer TravelMate P653-V-6882 RAM Replacement, Base Door: 步骤 4 中的图像 1,1
    • Remove the five 7mm Phillips #1 screws.
  5. Acer TravelMate P653-V-6882 RAM Replacement: 步骤 5 中的图像 1,1
    • Use the opening tool to separate base door from the bottom of the laptop.
    • Be careful not to bend or crack the plastic back cover.
  6. Acer TravelMate P653-V-6882 RAM Replacement: 步骤 6 中的图像 1,2 Acer TravelMate P653-V-6882 RAM Replacement: 步骤 6 中的图像 2,2
    • Gently pry open the base door by pushing up.
    • Pull out the base door.
  7. Acer TravelMate P653-V-6882 RAM Replacement, RAM: 步骤 7 中的图像 1,1
    • Locate the two RAM sticks on the bottom of the laptop.
  8. Acer TravelMate P653-V-6882 RAM Replacement: 步骤 8 中的图像 1,3 Acer TravelMate P653-V-6882 RAM Replacement: 步骤 8 中的图像 2,3 Acer TravelMate P653-V-6882 RAM Replacement: 步骤 8 中的图像 3,3
    • Pinch the two metal pieces holding the RAM sticks in place outwards.
    • Holding the sides of the RAM, slide the RAM sticks out.
    • Be careful not to touch the gold connection pins on the RAM sticks, as this could damage the RAM
结论
Basel Kandil
于01/18/20注册
85 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 206
