跳转到主内容
Acer TravelMate P653-V-6882 Keyboard Replacement
你所需要的
  1. Acer TravelMate P653-V-6882 Keyboard Replacement, Battery Pack: 步骤 1 中的图像 1,2 Acer TravelMate P653-V-6882 Keyboard Replacement, Battery Pack: 步骤 1 中的图像 2,2
    • Turn the computer over so the base is facing up.
    • Slide the battery lock to unlock position.
  2. Acer TravelMate P653-V-6882 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Slide the battery release latch to the right.
    • The battery pack will pop out.
  3. Acer TravelMate P653-V-6882 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Lift the battery up.
    • Pull out the battery.
  4. Acer TravelMate P653-V-6882 Keyboard Replacement, Base Door: 步骤 4 中的图像 1,1
    • Remove the five 7mm Phillips #1 screws.
  5. Acer TravelMate P653-V-6882 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Use the opening tool to separate base door from the bottom of the laptop.
    • Be careful not to bend or crack the plastic back cover.
  6. Acer TravelMate P653-V-6882 Keyboard Replacement: 步骤 6 中的图像 1,2 Acer TravelMate P653-V-6882 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Gently pry open the base door by pushing up.
    • Pull out the base door.
  7. Acer TravelMate P653-V-6882 Keyboard Replacement, Keyboard: 步骤 7 中的图像 1,1
    • Remove the two 7mm Phillips #1 screws.
  8. Acer TravelMate P653-V-6882 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Flip the laptop so that the underside is now facing the bottom.
    • Open the LCD panel.
    • Use the flat end of a spudger to push in the six latches.
    • Be careful not to bend or crack the keyboard.
  9. Acer TravelMate P653-V-6882 Keyboard Replacement: 步骤 9 中的图像 1,1
    • When the latches are pushed in, the keyboard will pop out.
    • Gently pry up the keyboard.
  10. Acer TravelMate P653-V-6882 Keyboard Replacement: 步骤 10 中的图像 1,1
    • Slide the keyboard forward to access the keyboard cable.
    • Flip the connector latch up to open it.
    • Pull out the keyboard cable gently.
    • Be careful not to damage the connector.
结论
Daniel Popovic
于01/13/20注册
985 声望
创作了7篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 430
