跳转到主内容
Acer Swift 3 2022 Screen Replacement
你所需要的
  1. Acer Swift 3 2022 Screen Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Be sure to power off the laptop before starting.
    • Flip the device over so the bottom panel is facing up.
  2. Acer Swift 3 2022 Screen Replacement: 步骤 2 中的图像 1,2 Acer Swift 3 2022 Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
  3. Acer Swift 3 2022 Screen Replacement: 步骤 3 中的图像 1,1
    • Use the iFixit opening tool to pry open the back of the device.
    • Remove the bottom cover from the laptop.
  4. Acer Swift 3 2022 Screen Replacement, How to Unplug the Battery: 步骤 4 中的图像 1,3 Acer Swift 3 2022 Screen Replacement, How to Unplug the Battery: 步骤 4 中的图像 2,3 Acer Swift 3 2022 Screen Replacement, How to Unplug the Battery: 步骤 4 中的图像 3,3
    • Peel back the strip of black tape.
  5. Acer Swift 3 2022 Screen Replacement: 步骤 5 中的图像 1,2 Acer Swift 3 2022 Screen Replacement: 步骤 5 中的图像 2,2
    • Unplug the group of wires by pulling the white plastic piece towards yourself.
    • Be careful, this piece can be easily damaged.
  6. Acer Swift 3 2022 Screen Replacement, Screen: 步骤 6 中的图像 1,3 Acer Swift 3 2022 Screen Replacement, Screen: 步骤 6 中的图像 2,3 Acer Swift 3 2022 Screen Replacement, Screen: 步骤 6 中的图像 3,3
    • Remove the EDP Cable located on the top right by pushing away from you.
  7. Acer Swift 3 2022 Screen Replacement: 步骤 7 中的图像 1,3 Acer Swift 3 2022 Screen Replacement: 步骤 7 中的图像 2,3 Acer Swift 3 2022 Screen Replacement: 步骤 7 中的图像 3,3
    • Remove the four 4.5 mm screws on the metal plates located on the top left and right hand corner using the JIS #1 screwdriver.
    • Flip up the metal plates.
    • The metal plates will be tight/hard to move.
  8. Acer Swift 3 2022 Screen Replacement: 步骤 8 中的图像 1,1
    • Open computer to a 90 degree angle by lifting the keyboard and sliding it out.
    • Place keyboard to the side so the screen is face up and the only thing in front of you.
  9. Acer Swift 3 2022 Screen Replacement: 步骤 9 中的图像 1,3 Acer Swift 3 2022 Screen Replacement: 步骤 9 中的图像 2,3 Acer Swift 3 2022 Screen Replacement: 步骤 9 中的图像 3,3
    • Insert the spudger between the computer screen and the black bezel.
    • Slide around the whole perimeter of screen.
    • Peel the bezel off.
  10. Acer Swift 3 2022 Screen Replacement: 步骤 10 中的图像 1,3 Acer Swift 3 2022 Screen Replacement: 步骤 10 中的图像 2,3 Acer Swift 3 2022 Screen Replacement: 步骤 10 中的图像 3,3
    • Disconnect the other end of the EDP Cable located next to the camera with the spudger.
  11. Acer Swift 3 2022 Screen Replacement: 步骤 11 中的图像 1,3 Acer Swift 3 2022 Screen Replacement: 步骤 11 中的图像 2,3 Acer Swift 3 2022 Screen Replacement: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    • Using the curved, fine-tipped tweezers, unstick the tape from the top of the case.
    • Once the tape is unstuck, pinch it with the tweezers and pull in the opposite direction.
    • Repeat on the other side.
    • The tape will stretch. You might have to regrip it.
    • You may only do this once. The tape will no longer be effective.
  12. Acer Swift 3 2022 Screen Replacement: 步骤 12 中的图像 1,1
    • Remove screen.
    • There will be some wires connected to the bottom of the screen. Pull them out carefully with the screen.
结论
另外一个人完成了本指南。
Anna Miller
于09/26/22注册
927 声望
创作了6篇指南
团队
1指南评论
really good i just followed the instructions and it was easy to do.
Sanchoi Dacres - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 30
过去 30 天: 93
总计 4,327
