跳转到主内容
Acer Spin SP513-52N Charging Port Replacement
你所需要的
  1. Acer Spin SP513-52N Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,1
    • Power off your laptop before beginning disassembly and disconnect the device from the charger.
    • Use a Phillips #0 screwdriver to remove twelve 6.0 mm screws from the back panel.
  2. Acer Spin SP513-52N Charging Port Replacement: 步骤 2 中的图像 1,2 Acer Spin SP513-52N Charging Port Replacement: 步骤 2 中的图像 2,2
    • Use an opening tool in the seam of back case and slide it around the perimeter to release the clips securing it to the top case.
    • Remove the back case to reveal the internals of the laptop.
  3. Acer Spin SP513-52N Charging Port Replacement: 步骤 3 中的图像 1,2 Acer Spin SP513-52N Charging Port Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Before replacing the charging port, unplug the internal battery from the motherboard.
    • Unplug the broken charging port from the motherboard with tweezers.
  4. Acer Spin SP513-52N Charging Port Replacement: 步骤 4 中的图像 1,1
  5. Acer Spin SP513-52N Charging Port Replacement: 步骤 5 中的图像 1,2 Acer Spin SP513-52N Charging Port Replacement: 步骤 5 中的图像 2,2
    • Use tweezers to insert the new charging port securely.
  6. Acer Spin SP513-52N Charging Port Replacement: 步骤 6 中的图像 1,1
    • Place the back case onto the laptop and press down around the edges of the perimeter.
    • You should hear the clips snap together.
  7. Acer Spin SP513-52N Charging Port Replacement: 步骤 7 中的图像 1,1
    • Use a Phillips #0 screwdriver to fasten the twelve 6.0 mm screws back into place.
结论
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%). Take your e-waste to an R2 or e-Stewards certified recycler.
Sara Al-Shumari
于01/10/21注册
145 声望
撰写一个指南
团队
York University, Team B-4, Allen Fall 2022 York University, Team B-4, Allen Fall 2022 的会员
YORK-ALLEN-F22SBG4
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 35
总计 1,204
