跳转到主内容
Acer Spin 7 SP714-51 Wi-Fi Card Replacement
你所需要的
  1. Acer Spin 7 SP714-51 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 1 中的图像 1,3 Acer Spin 7 SP714-51 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 1 中的图像 2,3 Acer Spin 7 SP714-51 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 1 中的图像 3,3
    • Turn the laptop so that the back cover is visible and facing you. Make sure it is on a flat surface, such as a table.
    • Using a standard PH0 Phillips-head screwdriver, work your way around the edge removing the 6mm screws along the way.
    • Once all the screws are removed, you should easily be able to remove the back cover. This can be done by hand or by using a Spudger as seen in the tools list.
    • Once the back cover is removed, make sure you disconnect the battery cable.
  2. Acer Spin 7 SP714-51 Wi-Fi Card Replacement: 步骤 2 中的图像 1,1
    • Disconnect the white and black antennae from the Wi-Fi card.
    • The Wi-Fi card is located on the left side of the laptop when it is flipped to see the bottom of the laptop.
    • The antennae should snap off upwards easily with a pry tool so the antennae and Wi-Fi card no longer connect.
  3. Acer Spin 7 SP714-51 Wi-Fi Card Replacement: 步骤 3 中的图像 1,2 Acer Spin 7 SP714-51 Wi-Fi Card Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the 6 mm retaining screw from the Wi-Fi card, and carefully pull the card free to remove it from the laptop.
结论
Zach Desrosiers
于03/22/22注册
565 声望
创作了5篇指南
团队
UMass Dartmouth, Team 7-3, Sinclaire Spring 2022 UMass Dartmouth, Team 7-3, Sinclaire Spring 2022 的会员
UMASSD-SINCLAIRE-S22S7G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 249
