简介
This is a guide on how to perform a touchpad replacement on an Acer Spin 5 SP515-51GN-807G laptop. The touchpad is a very important part of the device since it is the main peripheral the user uses to interact with when it is in laptop mode. If the touchpad doesn’t work properly, it is still possible to use the device since it can also be used as a tablet, but for users who prefer a traditional laptop interface, then it is best to make sure the touchpad works perfectly.
你所需要的
Remove the eleven 6.5 mm screws that secure the back case using a Phillips #1 screwdriver.
Unplug the 2 ribbon cables connecting the trackpad to the motherboard by flipping up the locking tabs of the ZIF connectors and pulling out the cables.
